The most interesting zone 1 robot in the world.
My team is NOT going to employ this strategy. Seriously.
Last night it was brought to the idea table when we were done working on important things. That it is possible to truss shot passively from zone 1. This robot or BOX has a 35 to 45 angle trampoline built into the frame up to a height of 5'. The human player inbounds the ball by throwing the ball directly at the trampoline. Thus arcing it IMMEDIATELY across the field and over the truss just by the ball bouncing off the said trampoline. You have 10 points right there. Last edited by JohnFogarty : 04-02-2014 at 15:29. Reason: You need wheels & I forgot about the side of the field you have to be on to score. I was only reading the in-bounding rules. |
Re: The most interesting zone 1 robot in the world.
Scores only count if they're shot from the same side of the field as the goals.
While I personally might be on board counting it as POSSESSION, I bet some more conservative rule-readers would not count that as a posession.
Relevant quotes: Quote:
I knew I missed/forgot something. So scoring in the goal isn't possible/legal.
Plus not having wheels is a very stupid choice to begin with. So I edited my first post. Still.... I think a passive truss shot employing this method is legal. |
#7
I wouldn't call it a possession after the team update. And, even if it was legal, that would have to be quite a throw to bounce all the way into the goal!
#8
Another thing to keep in mind would be that you would have to either start in the goalie zone or start in the white zone and not be able to score a ball in auto. Also if the set up would be in the goalie zone another thing to keep in mind would be the angle at which the trampoline is in relation to the human player. If the trampoline was parallel to the alliance wall, you're going to lose distance in how far you can get the ball down the field.
#9
You start in the auto zone. Then you drive over and park next to/near the wall where your human player inbounds the ball. This could be your teleop cycle strategy. You could have built a shooter for auto onto this robot, and then of course there are the 2 ball autonomous robots.
The main idea of this thread is...are passive truss shots possible/going to be a thing. |
#10
Unless your trampoline is in motion when the ball hits it, it is considered deflection and not possession. Cool idea, but really only executable by a robot with an active mechanism.
