Go to Post Now stop reading CD, do your homework, eat your peas, brush your teeth, and go to bed. Any time you spend speculating as to what Dave's ravings might mean is completely wasted. - Richard Wallace [more]
Unread 04-02-2014, 15:39
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
Equation for joystick input to Talons
hello all, we currently have decided to look into tweaking the operator controls of driving the robot. we currently have the joystick to Talon equation as a linear equation: y=x. What the joysticks get is sent to the talons. Each get values between -1 and 1. I'm sure you know this. y is what the Talons receive and x is the joystick input. What we're looking for is an equation that starts out slow, but once you get x to be around .4 to .6, y should be roughly equal to the x value. Past that, the y value should rapidly increase until you reach where x is around .75 or .8, where it should become very close to 1.
Example point table:
x,y
0,0
.1,.005
.5,.5
.6,.8
1,1
I know it may not be much, but I am also wondering what you may have used. this isn't really an issue with sensitivity, we are just looking to drive a little more slowly when the joysticks are lightly touched, but once they get past .6 or .7, drive very closely to full power if not full.
I understand we can do this with simple if statements, but an equation would make it... "flow"... much better.
Thank you for your help
Unread 04-02-2014, 15:46
Re: Equation for joystick input to Talons
Something like this?
Here's how to do it.
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
You could use an interpolation table.
Basically, you make a table like you already made, and the software linearly interpolates between the points. Super easy to write, calibrate, etc.
I wrote a LV VI to do this (it's in the BuzzLib download here). I can try to dig up my C version if anyone wants it.
Kettering Motorsports
Unread 04-02-2014, 15:49
jtrv's Avatar
github.com/jhtervay
AKA: Justin
Here is an sketch I drew up, I'm not entirely convinced that if I found it's equation we would use it, but it was my first idea.
http://i.imgur.com/57TuSZw.jpg (ignore the scribble )
@ the posted image:
yes, i have come across those equations in my searches. i would like something that changes concavity once it reaches roughly .5. nothing extremely fancy like my sketch, but something of the likes. my sketch doesn't reflect this paragraph, btw. i'm probably confusing you all. sorry about that.
Unread 04-02-2014, 15:53
Post or PM me a set of (x,y) points defining your desired curve, and I will generate a function for you.
Or I can show you how to do it yourself.
Unread 04-02-2014, 15:56
jtrv's Avatar
github.com/jhtervay
AKA: Justin
I've know the basics of how to do it with f'(x) and f''(x), but the only problem I run across is changing the way the curve "bends" per se... If you could PM me how you do it that would be fantastic.
Unread 04-02-2014, 15:59
apalrd's Avatar
More Torque!
VRC #3333
If you must have an equation, you could type your in->out pairs into Excel, graph them (x vs y), then add a trendline and use the equation.
Unread 04-02-2014, 16:01
jtrv's Avatar
github.com/jhtervay
AKA: Justin
Will try that now, completely forgot about this. thank you.
Unread 04-02-2014, 16:02
apalrd beat me to it. see his post.
Unread 04-02-2014, 16:05
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
http://www.wolframalpha.com/input/?i...nd+%281%2C1%29
Wolfram Alpha can do some magic... try tweaking this around a bit
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 04-02-2014, 16:13
jtrv's Avatar
github.com/jhtervay
AKA: Justin
Thank you for that wolframalpha link! I didn't know you could do that. We will definitely be tweaking that. I've found an equation to use for now by means of Excel - y = 0.9703x^5 - 2.673x^4 + 0.3901x^3 + 2.0981x^2 + 0.2075x. It seems to look good and we will be testing it on the drive train soon. Thank you to all your posts! Definitely helped.
Unread 04-02-2014, 16:17
apalrd's Avatar
More Torque!
VRC #3333
If you have even powers in your equation, you will have to take the abs of the input variable and multiply the output by the sign of the input, because you will lose the sign on the even terms but not the odd terms.
An equation with all odd powers would not do that.
Unread 04-02-2014, 16:31
jtrv's Avatar
github.com/jhtervay
AKA: Justin
Yep, I've got that accounted for.
Unread 05-02-2014, 01:20
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
For a basic interpolation given a few points, this should give you an idea. Your particular data points wouldn't produce a perfect equation fitting into ±1 range, but that can be fixed with some scaling. I would really like to know if there's an alternative to doing it this way, though :)
Unread 05-02-2014, 08:43
Cubic splines
