Go to Post One thing that FIRST has given me ... Friends who care. - Arefin Bari [more]
Unread 04-02-2014, 21:08
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
addSequential NOT Working for Servos
I have two programs to run a servo - if I assign the programs individually to buttons they work but if I build a command group with those two commands in it - so they go one after another - nothing happens - I assigned this command group to a button and it doesn't work - nothing happens when I assign the group as the autonomous command either.
Here it is:
addSequential(new Move45());
addSequential(new Move0());
ANY help will be GREATLY appreciated! THANKS!
Unread 04-02-2014, 21:41
Re: addSequential NOT Working for Servos
what do the commands look like? I'm guessing you're sending the servo one command to go to 45 degrees (for ~20ms) then immediately telling it to go back to 0.
Unread 04-02-2014, 21:56
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
you might want to add :
addSequential(new WaitCommand(timeout));
This will pause for the specified amount of time between the two commands.
Unread 04-02-2014, 23:27
LFRobotics's Avatar
FRC #4623
Here are the commands:
package edu.wpi.first.LFRobot2014.commands;
 * @author FrankyMonezz
public class PrepBall extends CommandBase {
    public PrepBall() {
        // Use requires() here to declare subsystem dependencies
        // eg. requires(chassis);
        requires(launchservo);
    // Called just before this Command runs the first time
    protected void initialize() {
    // Called repeatedly when this Command is scheduled to run
    protected void execute() {
        //move servo to 45 degrees
        launchservo.setPos(45);
    // Make this return true when this Command no longer needs to run execute()
    protected boolean isFinished() {
        return (launchservo.getPos() == 45);
    // Called once after isFinished returns true
    protected void end() {
    // Called when another command which requires one or more of the same
    // subsystems is scheduled to run
    protected void interrupted() {
public class PrepBall2 extends CommandBase {
    public PrepBall2() {
        //move servo back to default location
        launchservo.setPos(0);
        return (launchservo.getPos() == 0);
I will try putting in a wait command tomorrow - THANKS!
Unread 04-02-2014, 23:56
kylelanman's Avatar
kylelanman kylelanman is online now
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
A delay should fix your problem. While you are using what seems like a logical isFinished condition the reality is that it won't work. A servo provides no feedback to the rest of the system. A servo takes time to move from point A to point B. calling setPos(45) and then calling getPos() will yield 45. getPos() only tells you where the servo was last set. It doesn't take into account where the servo actually is.
Kyle
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
