Go to Post Temp wiring is always bad but it is made worse when dealing with a $1000 part. You wouldn't try to lash a makeshift power source to your PC. - Al Skierkiewicz [more]
Unread 03-02-2014, 15:28
Re: Team 842 Testing Shots
Originally Posted by rai337 View Post
Is there any specific reason why you put your pistons in such starting angle?
With a motor, you use a gearbox to trade speed for torque.
With a pneu cylinder, you use leverage to trade force for speed.
Unread 03-02-2014, 17:32
Bewizardment Bewizardment is offline
Team Role: CAD
Bewizardment is an unknown quantity at this point
How are you guys loading the ball? Does the arm go down further?
Unread 03-02-2014, 18:54
sergioCorral842's Avatar
sergioCorral842 sergioCorral842 is offline
College Student
FRC #0842 (Falcon Robotics)
sergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to behold
Originally Posted by Mr. Lim View Post
How are you precisely varying the timing of the pulse to the solenoid? Are you just counting cycles in the teleop periodic loop? Does that limit you to about 20ms increments? Do you need anything more precise than that?
This is very cool stuff.
I basically use the Timer class. It does not seem to be having any issues with that.
Team 842 Falcon Robotics: 2011-2015 (President, Head Programmer, Drive Team)
Arizona Regional Winners: 2012-2014 (Thanks 610, 1212, 1726, 3944, 2486, 2403)
Curie Division Semi-Finalists: 2014 (Thanks 1311, 2013, 2928)
Las Vegas Semi-Finalists: 2015 (Thanks 3495, 4415)
Curie Division Quarter-Finalists: 2015 (Thanks 107, 228, 649)
2015 - 2016: Programming, Drive Team, and Strategy Mentor for Team 3187, The Titans
Studying Computer Science- Software Engineering at ASU (Class of 2019)
Unread 04-02-2014, 00:21
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
That pile of broken ceiling tile has nothing to do with the robot right?
Queen's Applied Science '13, Applied Mathematics
Unread 04-02-2014, 00:29
College Student
Robots*
Unread 04-02-2014, 20:06
Team 2016's Avatar
Team 2016 Team 2016 is offline
Mighty Monkey Wrenches
FRC #2016 (Mighty Monkey Wrenches)
Team Role: Student
Team 2016 has a spectacular aura aboutTeam 2016 has a spectacular aura about
Could this be used to pass or catch?
Unread 04-02-2014, 21:15
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
Could you please explain in greater detail how to implement this?
Unread 04-02-2014, 22:13
College Student
Use the timer class to set the pistons to true for a certain amount of time then set them to false right after.
Unread 04-02-2014, 22:31
JohnFogarty's Avatar
JohnFogarty JohnFogarty is online now
AKA: @doctorfogarty
The amount of inspiration this video has given me cannot be quantified.
What solenoid are you using? is there any special storage tank between the solenoid and the cylinder? Or is it just
Compressor ---> Pressure Sensor -----> Storage Air Tank ----> Regulator ----> Solinoid ----> Cylinder.
*Forgive me for my lack of pneumatic knowledge if that order is so wrong that I deserve to be flogged.
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
Unread 04-02-2014, 22:53
kuraikou's Avatar
kuraikou kuraikou is offline
AKA: Alex
FRC #4183 (Bit Buckets)
kuraikou is an unknown quantity at this point
Super cool!!! I look forward to seeing you at the AZ regional.
In the videos your team posted on Facebook you have another piston that goes up and down as you fire, what is the point in this and how does it work?
2012 Utah regional Rookie All Star
2013 Phoenix regional Judges Award
2014 Hub City Quality Award
2014 Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award
2015 Arizona East Regional winning alliance captain
Unread 04-02-2014, 22:56
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Compressor, pressure sensor, primary storage tank, regulator, secondary storage tank, solenoid, cylinder
Faridodin "Fredi" Lajvardi KD7WKD
Unread 05-02-2014, 00:56
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
That additional piston gives us the ability to adjust the trajectory further. Just by varying the pulse to the main catapult cylinders, we are able to make a relatively lofty truss shot and a pretty hard/flat high goal shot. The geometry of the arm for those shots doesn't work for the in-front-of-the-1pt-goal high goal shot, so we added another degree of actuation.
We did a few quick tests today that make a self caught shot over the truss look feasible using these additional pistons; it will be pretty neat if we can pull that off in a match!
Unread 06-02-2014, 01:29
mithril865 mithril865 is offline
AKA: Mark Buckner
FRC #4265 (Secret City Wildbots)
mithril865 is an unknown quantity at this point
First let me say how impressive this design is. The flexibility is incredible! Can you please provide more details on how you implemented it including cylinder dimensions (bore & stroke), release, distance cylinders are attached from the pivot, pneumatic connections, are you using 2 tanks per cylinder? are you using separate solenoids for each cylinder? Our team tried to replicate your set up tonight and couldn't get anywhere close to the range you demonstrated.
Thanks...
Unread 06-02-2014, 03:19
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Our team used a different mechanical approach to varying our shots with the same shooter mechanism.
After seeing this thread early yesterday, we have already tried with great success the software pulsing of the solenoids instead.
Thanks for sharing.
Unread 06-02-2014, 14:56
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
OK, we had similar size cylinders, similar sized catapult, and tanks directly connected to the cylinder ports (mechanical release - we didn't even get into large CV solenoid valves yet) and we could not make our shooter make long shots like yours. We clearly have some learning to do. I'm looking forward to seeing more of your system after build season!
