Go to Post Dean's "All Denim" (now referred to as "Deanim") look is apparently catching on. - AndyB [more]
Unread 04-02-2014, 22:19
Re: Sensor Issue
When you copied the front panel controls to teleop, did you make sure the values stayed the same?
Unread 05-02-2014, 12:14
ROBOGIRL2781 ROBOGIRL2781 is offline
FRC #2781
ROBOGIRL2781 is an unknown quantity at this point
Re: Sensor Issue
Yes. All values are the same.
Unread 07-02-2014, 16:18
FRC #2781
Re: Sensor Issue
Here is a pic of the front panel...I am unsure if there are any other VIs I need to add a front panel to other than teleop...
Unread 07-02-2014, 16:26
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Sensor Issue
We had this issue when we tried using the "Digital", or "PWM", output. We ended up just choosing to use analog, as you did here.
The one thing to remember about this sensor is, it only samples at a 10Hz rate. Anything beyond that is not getting you any additional data, and may be corrupting your readings..
With the default config, you are sampling it at 1KHz.
Try setting the sample rate down to 10Hz and see how it works.
(We ended up re-building the digital interface and it worked like a charm. I have NO CLUE why it failed previously!)
Unread 07-02-2014, 17:59
FRC #2781
Re: Sensor Issue
I edited the code, but its still not functioning
Unread 07-02-2014, 23:57
billbo911's Avatar
Re: Sensor Issue
Dividing the value by 9.8 is only off by a factor of 1000.
It should be .0098.
Unread 08-02-2014, 10:47
FRC #2781
Re: Sensor Issue
I changed the scaling but it still does not show its working...is there specific numbers for the AverageBits and OversampleBits?
