Go to Post Well, it's officially that part of the offseason where we all lose our minds again. - Whippet [more]
Unread 29-01-2014, 22:04
Mubtasim Mubtasim is offline
FRC #4797
Mubtasim is an unknown quantity at this point
How to grdually speed up the robot?
We are trying to make it so that when the joystick signals to seed up, there has to be several milliseconds delays in order to gradually increase the speed. Is there any simple way to do this? [ using simple robot template ]
Thanks
Unread 30-01-2014, 09:18
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: How to grdually speed up the robot?
Thanks
You can keep track of an output variable and add a percentage of the error between it and the desired output each loop. Something like:
float output = 0.0;
while(true)
    float desired = joystick.getY();
    float error = desired - output;
    output += error * 0.1;
    motor.set(output);
Unread 30-01-2014, 09:39
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
We use what's called a rolling average to accomplish this. You keep a list of the past X values and average them together to get the current value. Each iteration you add the new value at the end and drop the first value. The more numbers you store the slower the system will react to changes. We wrote a utility to do this, I can get one of our students to post the code for it if you'd like.
Unread 30-01-2014, 09:41
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
What problem are you trying to solve? Are you trying to prevent spinning your wheels on acceleration? Preventing stress on the drivetrain when reversing direction quickly? Or just generally going for more control and less 'twitchiness'?
Eddie12390 has the right idea, but you need to manage each situation of input. For instance what will happen if you are going full speed and get a joystick input of full forward (-1.0). If you exactly cut and paste that code without at least limiting it you will be out of range for the motor input.
But his concept is sound for the problem as stated: take some percentage between where you are now and where you want to be and apply it. Just make sure you account for all situations.
Unread 30-01-2014, 10:09
Yes.
change = joystick - limitedJoystick;
if (change>limit) change = limit;
else (if change<-limit) change = -limit;
limitedJoystick += change;
limit is the amount of change you will allow every iteration (e.g. every 20 milliseconds for TeleOp)
limitedJoystick is the rate-limited joystick value you use to control your motors.
Here's an article which might be of interest:
http://thinktank.wpi.edu/article/140
Unread 04-02-2014, 20:33
James Lightfoot James Lightfoot is offline
Programming & Electrical Mentor
FRC #3737 (Rotoraptors)
James Lightfoot is just really niceJames Lightfoot is just really niceJames Lightfoot is just really niceJames Lightfoot is just really niceJames Lightfoot is just really nice
Yes.
Hello all. Rocky mentor here w/ a quick question. Wheter we use a Logitech joystick or an Xbox controller (on USB), does a stick give a value of -1 to 1 (analog) or -1, 0, +1 (digital)?
Thanks
Unread 04-02-2014, 21:16
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Thanks
Values from the joystick are continuous, so a value of 0.3 when pushing an axis forward slightly is reasonable.
We typically output the values so they can be viewed in NetConsole, like this:
System.out.println("X: " + joystick.getX() + ", Y: " + joystick.getY() + ", Rot: " + joystick.getTwist() );
However, we found out (we switched to java this year, it used to work in C++) that the getRotate() didn't work as we expected, so instead we use
double rotate = joystick.getRawAxis(4);
In fact, joystick.getTwist() for us was returning 0 until we moved it a bit, then it'd be stuck at 1. Not sure what's going on there....
Unread 04-02-2014, 22:47
It looks like C++ defines the twist axis as Axis 4 and Java defines it on Axis 3. This is probably due to different joysticks behaving differently. I know the Logitech Axis 3 defines the throttle on Axis 3 and doesn't have a twist, but the Logitech Extreme 3d Pro defines the twist on Axis 3 and throttle on Axis 4.
I filed artf1718
Unread 05-02-2014, 18:42
DonRotolo's Avatar
Back to humble
FRC #0832
We did this once. Our drivers hated it.
Unread 05-02-2014, 18:46
How slow was your ramp rate?
Unread 05-02-2014, 19:57
Jared Russell's Avatar
Taking a year (mostly) off
Another way to do this is:
motor_value = k*joystick_reading + (1-k)*motor_value
k is between 0 and 1.
Large k values make the motor very responsive, and a value of 1 means no filtering is actually happening. Small values make the output move slowly from the old value to the joystick value.
This is an Infinite Impulse Response (IIR) low pass filter, whereas the moving average is a Finite Impulse Response (FIR) filter. Which of these to choose (or using a rate limiter like Ether suggested) depends on what exactly you are trying to accomplish.
My experience with using any sort of filtering in the drive train (other than traction control in 2009) is that drivers usually hate it because if the effect is significant it feels "sluggish".
Unread 07-02-2014, 08:04
Flywheel Police
We're using a moving average this year and chose our value based on if it felt laggy to the driver or not. We're only storing 10 values, but we figured something is better than nothing. We'll see how this season goes and decide if it is something that we'll continue to use.
Unread 07-02-2014, 09:20
Originally Posted by notmattlythgoe View Post
We're using a moving average this year...
What was the problem you were trying to solve by doing this?
Unread 07-02-2014, 09:21
Flywheel Police
Just trying to limit current draw when we can. We weren't really having a problem, just something we wanted to try.
