Go to Post oh, the prom! I thought you were missing a PROM (Programable Read Only Memory) ...you had me worried for a minute, I dont know if IFI has any spare PROMs. - KenWittlief [more]
Unread 04-02-2014, 21:19
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
How to Make the Robot Drive Forward in Autonomous
This may seem like a simple question but I can't get it to work. I am using commandbase java.
I have a chassis subsystem here:
package edu.wpi.first.LFRobot2014.subsystems;
import edu.wpi.first.LFRobot2014.RobotMap;
import edu.wpi.first.LFRobot2014.commands.DriveTele;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.command.Subsystem;
 * @author Developer
public class Chassis extends Subsystem {
    // Put methods for controlling this subsystem
    // here. Call these from Commands.
    RobotDrive drive;
    public void initDefaultCommand() {
        // Set the default command for a subsystem here.
        setDefaultCommand(new DriveTele());
    public Chassis(){
        drive = new RobotDrive(RobotMap.leftMotorPort, RobotMap.rightMotorPort);
        drive.setSafetyEnabled(false);
    public void driveTele(Joystick leftStick, Joystick rightStick){
       drive.tankDrive(leftStick, rightStick);
    public void setSpeed(double speed){
        drive.setMaxOutput(speed);
Do I use this same subsystem(which is the one that I base my TankDrive off of) to write a command that will run the motors for a certain time or do I write up a new subsystem? And what do I have to do code-wise to make this work?
THANKS!
Unread 04-02-2014, 21:36
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Re: How to Make the Robot Drive Forward in Autonomous
You use the same subsystem.
Add the following method:
public void driveAuton(double speed, double turnRate)
	drive.arcadeDrive(speed, turnRate);
You can then call this method in a command that you make for autonomous. Feel free to use the turning feature too, although don't expect to get much accuracy with it (actually, don't expect to get much accuracy with this method at all).
To implement timing is also pretty simple. In the init of your command, type: setTimeout(timeToRun); (replace timeToRun with the amount of time you want to drive forward. Then, in the isFinished of your command, type: return isTimedOut();
Unread 04-02-2014, 21:37
xForceDee's Avatar
xForceDee xForceDee is offline
AKA: Bart Kerfeld
FRC #4239 (Warpspeed)
xForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to behold
I think this should work...
Add this method to Chassis.java
public void driveAuto(double speed) {
     drive.setLeftRightMotorOutputs(speed, -speed); //The - may be wrong
Then make a new command which requires chassis and calls this method. If your auton needs to be more sophisticated than drive forward, you can always add the command to a command group. Anyway, this is just one solution of the many out there.
Last edited by xForceDee : 04-02-2014 at 22:19. Reason: Be sure to add double in the parameter (getting too used to python)
Unread 04-02-2014, 23:33
LFRobotics's Avatar
FRC #4623
Okay - THANKS guys!
