Go to Post On the one hand, I wouldn’t want to discourage innovation. But on the other, I would want to encourage simplicity. - Jack Jones [more]
Unread 02-04-2014, 11:56 PM
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: addSequential NOT Working for Servos
A delay should fix your problem. While you are using what seems like a logical isFinished condition the reality is that it won't work. A servo provides no feedback to the rest of the system. A servo takes time to move from point A to point B. calling setPos(45) and then calling getPos() will yield 45. getPos() only tells you where the servo was last set. It doesn't take into account where the servo actually is.
Kyle
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
