Go to Post We've done all the speculation we can do (some of us with less knowledge than others); let's rest our minds and keyboards and wait. - Astrokid248 [more]
Unread 05-02-2014, 00:33
tag_groff's Avatar
tag_groff tag_groff is offline
FRC #4265
tag_groff is an unknown quantity at this point
pic: coupling for dual cylinder ballshifter
Unread 05-02-2014, 00:34
Knufire Knufire is offline
Re: pic: coupling for dual cylinder ballshifter
Are you planning to 3D print it?
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 05-02-2014, 00:44
Lexlukener's Avatar
Lexlukener Lexlukener is offline
Project Manager/Lead Engineer
AKA: Luke Buckner
FRC #4265 (Secret City Wildbots)
Lexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to all
Yeah!, We already did and mounted it looks great and we will be able to test it tomorrow
Unread 05-02-2014, 00:58
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
What's the reason for making this?
Need more oomph to shift, or maybe multiple positions?
Unread 05-02-2014, 01:55
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
How would you accomplish more than two positions with two cylinders? If they have different strokes, won't one just fight the other (not to mention cantilevering the coupling)?
If this for extra shifting power though, I would like to know what application it's being used for that requires a second cylinders to accomplish.
Unread 05-02-2014, 02:02
Betcha they're trying to shift a winch from windup to FIRE! and one cylinder wasn't cutting it. That was a pretty hot topic of discussion a week or two ago.
Unread 05-02-2014, 02:15
FRC #1360
Ah right, you can accomplish two different positions with two cylinders, but not if it is mounted to he same coupling. Yes, if they were different length strokes it would probably just shatter the coupling.
Long day of troubleshooting, must sleep.
I am surprised the ball shifter would need a 2nd piston based on Paul's (theoretical) math, but the extra help won't hurt and it's still nowhere near the force needed for a dog gear. Much more compact than a big bore cylinder and a lever arm!
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
Paul Copioli said it would theoretically still neutral with a 400 lb winch, but so far as I know, no one has actually tested this yet. I would love to see some video (or at least pictures) of someone using the standard piston and having it NOT neutral.
2014- 5031 Mentor
2013- 1310 Mentor
2012- 4258 Mentor
2011-2012 865 Mentor
2006-2008 1814 Team Captain, Main Driver, Mechanical
Unread 05-02-2014, 07:33
tag_groff's Avatar
FRC #4265
we were doing it with only a single piston at 60psi. we ended up having to up our regulator to even test. That is why we added the second cylinder. It works marvelously.
Unread 05-02-2014, 08:15
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
Don't suppose that you would be willing to share the cad files for this. Or offer to print another one for a small price? We were having the same issue last night testing our winch.
Unread 05-02-2014, 08:40
tag_groff's Avatar
FRC #4265
https://www.dropbox.com/s/4mveor2l36...oupling.SLDPRT
just print 2 and they mesh together
Unread 05-02-2014, 08:47
Cash4587's Avatar
Cash4587 Cash4587 is online now
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Do you care to share the mounting plate as well?
Unread 05-02-2014, 10:13
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
How much force are you putting on this? Our winch uses a 2-CIM Ball shifter as well, and we were able to shift it under competition-load from our catapult (we haven't fine tuned it yet, but it's close to where it'll be) using only 20 PSI!
2016: Lake Superior WFFA
Unread 05-02-2014, 10:29
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Looks like a great and innovative solution to needing more shifting force! We had never thought of using multiple cylinders to increase shift force (just upping cylinder size or adding a lever... neither of which work with our space constraints). I didn't notice a ratchet visible on your gearbox... is there one somewhere in your design?
We had designed for a dog-shift method and tried modifying the tooth geometry (grinding the surfaces on the dog and the dog-gear down slightly so that they're still parallel but no longer parallel to the axis of the shaft), hoping that would take enough of the friction force out. Alas that was unsuccessful, and using our standard .75" bore shifting cylinder we couldn't pull it out even at 100psi. I suspect this method would work eventually, but might not be as repeatable... Instead we've decided to "cut our losses" and switch to the ball-lock shift method.
I saw 2177 just commented that their ball shifter (2 CIM input?) worked fine with only 20psi of pressure... have other people also already tried the ball shifter for their winch-release? If so what're your findings? What's the torque on your output shaft (force * spool radius)?
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 05-02-2014, 10:50
I'll let you know what the torque is as soon as we get the 110lb fish scale we ordered from Amazon over the weekend. Less than $20, and it should help us make sure our catapult is calibrated the same every time we hit the field. (We didn't think the normal 20-40lb scales some of our friends have would cut it.. the fish here generally aren't bigger than that!)
Oh, and it's a 1-CIM input currently... we didn't want to go for 2 unless we need it.
