Go to Post We'll defenestrate our programmer, and I'll report back our solution if we get anything working. - Nick Seidl [more]
Unread 05-02-2014, 08:34
Re: Legal Pneumatic Fittings - Nipples & Elbows?
I read the flow specification on the valve as without fittings for the exhaust ports. So a 1/8" port with no fittings ought to have a higher flow rate than the same port with fittings inserted.
Unread 05-02-2014, 18:13
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
well, this still strikes me as a "1080p" TV sold with only an s-video input.
thanks for the info on the Cv of tubing and fittings, based on reading CD threads about flow restriction, I had assumed past KOP solenoids were significantly* worse than tubing and fittings, but I guess not...
*maybe a Cv difference of at least 0.1, as opposed to 0.03
Unread 05-02-2014, 22:07
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
Going back to the OP's question, I would suggest testing your setup with a nipple, and with the tubing. See if there is enough difference, or even good difference that would be worth risking the creation of a new rule.
One of our mentors had the same thought, and attached one of our higher Cv solenoids to an accumulator with a short brass nipple. Imagine our surprise, when the increased "performance" turned out to be detrimental to the actual performance of our catapult. Everything was promptly changed back.
Test your theory, and find out if you are just tilting at windmills with trying something that will attract attention from inspectors. You will at least satisfy your curiosity, and you may just find, as we did, that it isn't worth it.
Unread 06-02-2014, 13:33
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
Guys,
Can we agree that "we used it in the past" is not a response.
Thanks.
But Al, I have used that response in the past
Anthony Rubio
Co-Coach, Memento Vitam Team 5484, 2015-????
Mentor, Black Knights Team 135, 2009-2015
Student, Black Knights Team 135, 2007-2008
Unread 06-02-2014, 21:53
DonRotolo's Avatar
Back to humble
FRC #0832
Best. Response. Ever.
Unread 07-02-2014, 07:33
Why do you guys to this to me?
