Go to Post Sometimes, you just have to beat something (someone?) into submission. Yes, you can use your head, but its a lot easier with a hammer. - Andy A. [more]
Unread 05-02-2014, 04:37
Dan252 Dan252 is offline
FRC #3075 (HaDream Team #3075)
Dan252 is on a distinguished road
Problem with distance calculation
Hey,
We are using RoboRealm for vision processing this year but we are having problems with the distance calculation.
This is the code we have as of now: (the output distances are way off)
def IsVertical(n):
	return rr.GetArrayVariable("WIDTH")[n] < rr.GetArrayVariable("HEIGHT")[n]
width = 0
if IsVertical(i):
    width = VtargetWidth_in
    Hot[i] = False
else:
distance = width/(2*math.tan(cameraFieldOfView*(rr.GetArrayVariable("WIDTH")[i]/rr.GetVariable("IMAGE_WIDTH"))*math.pi/360.0))
[written in python]
Another one tried (better results, but still atleast 3ft errors): [this is only for vertical targets]
if IsVertical(i):
    d = VtargetRheight_in*imageHeight_px / (2*math.tan(cameraFieldOfView*math.pi/360.0)*rr.GetArrayVariable("HEIGHT")[i])
Any help would be welcome!
Unread 05-02-2014, 08:22
Re: Problem with distance calculation
Is the number for the camera field of view set correctly?
Unread 05-02-2014, 08:45
Yes, it is 47 degrees.
We are using the labview sample images though (with the real distance in their filename) and I'm not entirely sure what camera they used but we tried all of the fov angle options and still had no luck getting close enough results
Unread 05-02-2014, 16:22
Jerry Ballard's Avatar
Jerry Ballard Jerry Ballard is offline
AKA: Jerry Ballard
FRC #0456 (Siege Robotics)
Jerry Ballard is a jewel in the roughJerry Ballard is a jewel in the roughJerry Ballard is a jewel in the rough
Originally Posted by Dan252 View Post
Hey,
def IsVertical(n):
width = 0
if IsVertical(i):
    Hot[i] = False
else:
[written in python]
if IsVertical(i):
I'm not sure I understand all your variable names, but here's one way to do it
distance = ( targ_width_in / 2.0 ) / tan( 0.01745 * ( ( ( targ_width_pixels / cam_width_pixels) * cam_fov_deg ) / 2.0 ) ) ;
The 0.01745 is the degree to radian conversion. With typically only 640 or 720 horizontal pixels, additional precision isn't required.
If you precompute the individual camera pixel field of view (IFOV = cam_horizontal_fov / cam_horizontal_pixels), then it is a bit more easier to read:
distance = (target_width_in / 2.0 ) / tan( 0.01745 * (IFOV * target_width_pixels / 2.0 ));
The IFOV * target_width_pixels provides the angular width of the target.
Hope this helps.
