Go to Post You mean to tell me there's a weight limit this year?!?!?!!? - Carlo [more]
Unread 05-02-2014, 10:20
idoshamir idoshamir is offline
FRC #5038
idoshamir is an unknown quantity at this point
Robot Bumpers Rules
Hello,
Can someone confirm for sure that the attached picture is a legal build?
Bumper-wise - do we have to go the full 8 inch in?
Frame-wise - is this legal?
( http://imgur.com/ToEyS1k )
Thank you!
Unread 05-02-2014, 10:36
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Re: Robot Bumpers Rules
My understanding of the rules is that your configuration is legal.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 05-02-2014, 10:40
Jake177's Avatar
Jake177 Jake177 is offline
AKA: JT, Jake Troiano
FRC #0177 (Bobcat Robotics)
Jake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to behold
R19:
ROBOTS are required to use BUMPERS to protect all outside corners of the FRAME PERIMETER. For adequate protection, at least 8 in. of BUMPER must be placed on each side of each outside corner (see Figure 4-5). If a side is shorter than 8 in., the entire side must be protected by BUMPER (see Figure 4-6). For the purposes of R19, a round or circular FRAME PERIMETER has an infinite number of corners.
If you look at Figure 4-5 in the Manual, the lower-left picture expressly shows that this configuration would not meet the bumper requirements. The only time you are allowed to have less than 8" of supported bumper extending from a corner is when your Frame Perimeter has a side that is less than 8". (Such as in Figure 4-6.)
Once a Bobcat, always a Bobcat
2001-2004: Student
(I'm told the team had a couple good years in between here)
2012 - Present: Mentor
Unread 05-02-2014, 10:41
Professional Stat Padder
As long as you have 8 inches of bumper extending from each of those questionable corners, you should be fine. Really read the bumper rules carefully about how you have to support the bumper as well.
(2015-Present)
Unread 05-02-2014, 10:45
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
My understanding is that that configuration is not legal.
Bumpers must extend 8" from the corners of the FRAME PERIMETER. The FRAME PERIMETER is not defined as the actual perimeter of the frame, but the polygon defined by the external corners of the robot frame. The only exception is if one of the FRAME PERIMETER sides is less than 8". In your example, it appears there are 4 sides to your frame perimeter, so the extent from the corner that has a bumper should still be 8"
Disclaimer: I am not an inspector or the GDC.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
You must have a bumper 8" on each side of an exterior vertex.
each end of the bumper needs to be supported by 1/2" of frame.
So no you are not legal.
Unread 05-02-2014, 10:56
FRC #5038
Thank you all. So the majority here agrees that if the bumpers extend into the "hole" 8 inches both sides we will be OK?
I am also trying to get a formal answer for FRC, but I need a quick decision...
Unread 05-02-2014, 10:58
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
R19
Maybe I'm not understanding that correctly, but I think it would be legal.
Unread 05-02-2014, 11:22
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
The each end of the bumper will have to be supported by 1/2" of frame. If the bumper extends into a hole the end of it will have to be supported.
Unread 05-02-2014, 11:24
Ido,
Your drawing is not a legal bumper. In inspection this would be explained to you. The 8" minimum rule applies to the highlighted part of your frame. The 8" is measured on the frame or bumper backing. See Fig 4-5, you robot is the lower left drawing.
Unread 05-02-2014, 11:28
Jake177's Avatar
The term "side" in R19 refers to a side of the FRAME PERIMETER. In the given case, the robot's FRAME PERIMETER has four sides, all of which are greater than 8". It doesn't matter that one of the sides happens to have a gap in it, it is still required to have at least 8" of bumper at each corner.
2001-2004: Student
Unread 05-02-2014, 11:32
FRC #5038
I think we got it. Thank you all.
Unread 05-02-2014, 11:37
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Originally Posted by excel2474 View Post
R19
No, you aren't understanding it correctly. The "side" that is being referred to is a side of the FRAME PERIMETER - it would be the entire side of the robot, including the gap in the actual frame. Wrap a string around the robot and pull it tight - that's the FRAME PERIMETER, and it spans openings like in the drawing. The two short bumpers in the drawing are both on the same side, and thus both have to be 8" or greater in length.
2016: Lake Superior WFFA
