Go to Post The robots are the attracting force, the common interest that brings us all together - sanddrag [more]
Unread 05-02-2014, 11:27
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: pic: How do we operate this valve?
I'm pretty sure that's 1/8" NPT. That chromed fitting looks like the standard 1/4" OD tubing to 1/8" NPT fitting. Based on the fingers in the picture, that tubing looks to be a plausible 1/4" OD, and nominal OD for 1/8" NPT is about 0.4". So, while it's a beefy valve, that still appears to be in compliance with the rules. A good measurement to double check would be in order.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 05-02-2014, 11:45
Mr V's Avatar
Mr V Mr V is online now
FRC #5588 (Reign)
The two parallel terminals are most likely the ones you want to connect to. Grab your ohm meter and check the continuity between each of the terminals and the body of the valve. One should show infinite resistance between it and the other two and may show near zero resistance to the body of the valve. The other two should show measurable resistance. Or you could just google the part number and find the data sheet for that family of valves.
Unread 05-02-2014, 21:45
Nate Laverdure's Avatar
FRC #2363
You're probably right. Sorry OP!
