Robot Bumpers Rules
Hello,
Can someone confirm for sure that the attached picture is a legal build? Bumper-wise - do we have to go the full 8 inch in? Frame-wise - is this legal? ![]() ( http://imgur.com/ToEyS1k ) Thank you! |
Re: Robot Bumpers Rules
My understanding of the rules is that your configuration is legal.
As long as you have 8 inches of bumper extending from each of those questionable corners, you should be fine. Really read the bumper rules carefully about how you have to support the bumper as well.
My understanding is that that configuration is not legal.
Bumpers must extend 8" from the corners of the FRAME PERIMETER. The FRAME PERIMETER is not defined as the actual perimeter of the frame, but the polygon defined by the external corners of the robot frame. The only exception is if one of the FRAME PERIMETER sides is less than 8". In your example, it appears there are 4 sides to your frame perimeter, so the extent from the corner that has a bumper should still be 8" Disclaimer: I am not an inspector or the GDC. |
You must have a bumper 8" on each side of an exterior vertex.
each end of the bumper needs to be supported by 1/2" of frame. So no you are not legal. |
#7
Thank you all. So the majority here agrees that if the bumpers extend into the "hole" 8 inches both sides we will be OK?
I am also trying to get a formal answer for FRC, but I need a quick decision... |
#8
R19
ROBOTS are required to use BUMPERS to protect all outside corners of the FRAME PERIMETER. For adequate protection, at least 8 in. of BUMPER must be placed on each side of each outside corner (see Figure 4-5). If a side is shorter than 8 in., the entire side must be protected by BUMPER (see Figure 4-6). For the purposes of R19, a round or circular FRAME PERIMETER has an infinite number of corners. Maybe I'm not understanding that correctly, but I think it would be legal. |
#9
The each end of the bumper will have to be supported by 1/2" of frame. If the bumper extends into a hole the end of it will have to be supported.
#10
Ido,
Your drawing is not a legal bumper. In inspection this would be explained to you. The 8" minimum rule applies to the highlighted part of your frame. The 8" is measured on the frame or bumper backing. See Fig 4-5, you robot is the lower left drawing. Last edited by Al Skierkiewicz : 05-02-2014 at 11:26. |
#11
The term "side" in R19 refers to a side of the FRAME PERIMETER. In the given case, the robot's FRAME PERIMETER has four sides, all of which are greater than 8". It doesn't matter that one of the sides happens to have a gap in it, it is still required to have at least 8" of bumper at each corner.
#12
I think we got it. Thank you all.
#13
