Go to Post I think the only way I'd die from posting on CD is from my wife killing me. - Koko Ed [more]
Unread 29-01-2014, 22:41
charr charr is offline
FRC #3504
charr is an unknown quantity at this point
looking for sample - simple smartdashboard plugin which writes to networktable
This is really a unit test. I want to create a plugin which, when the smartdashboard starts, will start writing values to the network tables - perhaps a continuous sine wave.
Unread 05-02-2014, 13:10
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: looking for sample - simple smartdashboard plugin which writes to networktable
There is now a tutorial here: http://wpilib.screenstepslive.com/s/...rol-using-java
Watchdog.Kill();
Unread 05-02-2014, 13:23
FRC #3504
Thanks, that is helpful. But actually I was looking for an example for the old smartdashboard.
Originally Posted by byteit101 View Post
Unread 09-02-2014, 10:48
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
there was an example **buried** in last year's documentation... <rummage rummage>
I went through this over the summer: it worked well for the 2013 swing based dashboard, hope to see the same in 2014?
http://firstforge.wpi.edu/sf/wiki/do...reateExtension
Unread 09-02-2014, 16:11
fovea1959's Avatar
AKA: Doug Wegscheid
If it's not essential that the sine-wave generator is part of the dashboard (where does that requirement come from?), then you can just write and run a separate program to stuff the data into the network tables (this is what robo realm does). Integration with the dashboard is not necessary to access the network tables.
The PC desktop version of the network tables library in in sunspotfrcsdk\desktop-lib, along with Javadocs.
Unread 09-02-2014, 16:38
FRC #3504
As I had said in my original posting, this is about unit testing and not about any "requirement". Or to say another way, the requirement is for the following unit test: a smartdashboard which sends data to the network tables. I've still not found such an example.
Thanks,
Chris
Unread 09-02-2014, 20:38
fovea1959's Avatar
AKA: Doug Wegscheid
again, does it need to specifically be a smartdashboard, or just a Java program (it sounds like the latter)? In that case, the shorter route may be a standalone program to stuff the network tables.
package org.usfirst.frc3620.desktop.networktables;
import edu.wpi.first.wpilibj.networktables2.client.NetworkTableClient;
import edu.wpi.first.wpilibj.networktables2.stream.IOStreamFactory;
import edu.wpi.first.wpilibj.networktables2.stream.SocketStreams;
import java.io.IOException;
public class TableStuffer {
    public static void main(String args[]) {
        Throwable boom = null;
        try {
            String host = "10.36.20.2";
            if (args.length > 0) {
                host = args[0];
            int port = 1735;
            TableStuffer tableStuffer = new TableStuffer(host, port);
            tableStuffer.go();
        } catch (IOException ex) {
            boom = ex;
        } catch (RuntimeException ex) {
            boom = ex;
        if (boom != null) {
            boom.printStackTrace();
    NetworkTableClient client = null;
    TableStuffer(String h, int p) throws IOException {
        IOStreamFactory streamFactory = SocketStreams.newStreamFactory(h, p);
        client = new NetworkTableClient(streamFactory);
    void go() {
        double degrees = 0;
        while (true) {
            if (!client.isConnected()) {
                client.reconnect();
                // fresh connection, restart the since wave
                degrees = 0;
            } else {
                double s = Math.sin(degrees * Math.PI / 180.0);
                System.out.println (degrees + " -> " + s);
                client.putDouble("degrees", degrees);
                client.putDouble("sin", s);
                degrees ++;
            try {
                Thread.sleep(50);
            } catch (InterruptedException ex) {
