Go to Post After all, when any student is isolated because of a difference - because of race, gender, social beliefs, or ideological concepts - we all lose. - MysterE [more]
Unread 05-02-2014, 13:34
DBortnick's Avatar
DBortnick DBortnick is offline
AKA: Daniel
FRC #1850 (Mechanicats)
DBortnick is on a distinguished road
Question 3/8" Hubs
Hey Chief Delphi,
I made a mistake early on in the season when ordering parts and underestimated the number of 3/8" hubs my team needs for our design:
http://www.andymark.com/product-p/am-0134a.htm
AndyMark is out of both of their 375 Key Hub versions. Obviously this is a popular product this season. I've looked at a few other websites and can't find any comparable products that are available. Are there any sites that you know of that has something like this?
Worst case scenario, I know we can change the shaft size and use different sized hubs. However, we've already invested a decent amount in the proper slotted rod, pillow blocks, and other things that would work for 3/8" shaft.
Coach for Team 1850
ACE Technical Mechanicats - Chicago, IL
http://www.facebook.com/Team1850
Unread 05-02-2014, 13:40
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: 3/8" Hubs
Do you have access to a 3D printer? You could always print some temporary hubs while waiting for the back ordered hubs.
Otherwise you could get a solid tube of aluminum and drill out the center with a hand drill. If you have access to a mill and a lathe you could make them yourself relatively easily, provided you have the time.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 05-02-2014, 13:43
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
Re: 3/8" Hubs
You couyld buy 1/4" hubs and bore them out to 3/8" and broach the key yourself.
http://www.andymark.com/product-p/am-0215a.htm
Unread 05-02-2014, 13:50
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: 3/8" Hubs
Or bore them out and then add set screws since they might not have a broach.
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 05-02-2014, 13:53
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Re: 3/8" Hubs
1. Like others are suggesting: If you got a drill press and a decent arbor press you could buy the .25" drill it out to 3/8" and broach the key way.
2. If you got a mill or perhaps a drill press you could make a dutch key. A dutch key is made by drilling/milling parallel to the shaft forming a round key way. You could do this with the 3/8" hex hub, drill out a round key way and push in a pin to make a key. This is weaker the method 1
3. Alternatively order the 3/8" hex and shove a shim or shaved down key into shaft key way. Probably the weakest solution.
2 and 3 could get you going until you get the parts you need. 1 probably the best.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 05-02-2014, 14:13
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: 3/8" Hubs
We have been adapting our own belt pulleys and find that a ream is far better than a drill for fitting the shaft. A 3/8 drill is not exactly 3/8 but a ream is.
Unread 05-02-2014, 14:26
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: 3/8" Hubs
Set screws and lock tight will get you out of a bind.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 05-02-2014, 14:35
DBortnick's Avatar
AKA: Daniel
Re: 3/8" Hubs
Great suggestions.
We do not have an arbor press but we do have a decent drill press and a lathe. Getting the 1/4" hub and drilling it out to 3/8" might be our best bet at this rate.
Thanks for your help!
Coach for Team 1850
