Go to Post Robots will consume you if you are not careful. - JohnBoucher [more]
Unread 04-02-2014, 09:21
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
Brake or Coast with a spike?
Does anyone know if a spike controller coasts or brakes when enabled? We have a motor that we only need to run at full speed in two directions, but it needs to be able to coast. We would like to know if we can use a spike for easier mounting (we don't have much room for electronics) or if we need to use a speed controller.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
Unread 04-02-2014, 09:26
Re: Brake or Coast with a spike?
There is no real coast on the Spike. If you look at the manual you will find the truth table for output. The outputs can be set high or low but not open.
Unread 04-02-2014, 12:25
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
You did not say what motor. It is not legal to run the larger (CIM ect) motors on a spike regardless of coasting.
Unread 05-02-2014, 14:26
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
The tallons do have a brake / coast jumper you can set?
Unread 05-02-2014, 14:27
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Yes, all of the FRC motor controllers have this feature.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 05-02-2014, 14:40
If I may be permitted a brief moment of pedantry, the VEX Motor Controller 29 doesn't have a brake/coast selection. It's only permitted in conjunction with the VEX 2-wire Motor 393, which doesn't really coast effectively anyway.
