Go to Post Why follow when you can lead? - Elgin Clock [more]
Unread 05-02-2014, 10:59
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
solder a bracket to a brass pneumatic fitting?
Is it legal to solder a bracket to a brass 3 way fitting so it can be mounted to my chassis or is soldering considered "altering"?
Big Al. I would appreciate your insight here.
Thanks
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 05-02-2014, 11:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: solder a bracket to a brass pneumatic fitting?
I don't know the legality (only the GDC does), but it sounds like something that would cause inspection problems. How about making a bracket that clamps to the fitting? Or the good old standby of zip ties...
Unread 05-02-2014, 11:49
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I would consider that altering. When soldering to brass, there's no way for an inspector to know how hot the material got, or if the integrity of the fitting was compromised. The last thing we want is for the fitting to blow out and either reduce your robot performance on the field or injure someone nearby (granted, I think this is a much lower likelihood given this particular situation).
Personally, I would just zip tie the fitting in place and call it good.
2016: Lake Superior WFFA
Unread 05-02-2014, 12:35
Bruceb's Avatar
well just a zip tie wont work as it is part of the guage, pressure release valve, etc but I guess I can mill a clamp or something.
Thanks for the feedback.
Unread 05-02-2014, 15:20
MrForbes's Avatar
AKA: Jim
We usually try to mount that stuff to the compressor and to the regulator, generally about half on each, then it has something solid to hold it. Alternatively you can use quick connect fittings and plastic TEEs instead of brass TEEs, then zip ties don't have to deal with as much weight.
Unread 05-02-2014, 15:21
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
If I were inspecting, I'd flunk that. That is an alteration of a part. Sorry
Ed Barker
Unread 05-02-2014, 15:28
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Team Role: CAD
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
As someone stated before, zip ties work just as well. You can make the bracket to connect to your chassis, then drill holes out and feed strong zip ties through to connect each end/side of the fitting. This substitutes the illegal soldering.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 05-02-2014, 15:45
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Epoxy wouldn't work?
Unread 05-02-2014, 17:08
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
As an Inspector, the soldering would definitely raise questions, and Epoxy would probably make me call the LRI (if I noticed it). I don't know enough about the possible chemical reactions between whatever form of epoxy used and brass to know if there is risk of compromise.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 05-02-2014, 17:46
DonRotolo's Avatar
Back to humble
FRC #0832
I'd also flunk that, also with epoxy.
Unread 05-02-2014, 18:00
You may not modify pneumatic parts. A famous vendor from Kokomo was reminded of that at Champs two years ago.
Unread 05-02-2014, 19:32
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
After I warned him!
Unread 05-02-2014, 19:57
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Why would you flunk a fitting that has been glued in place?
Would VHB or a double-stick tape be okay in your opinion?
Unread 06-02-2014, 13:57
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
It's the usual problem of whether adhesive fastening should be considered a violation of the rule that "[a]ll pneumatic COMPONENTS must be used in their original, unaltered condition" (with exceptions).
Given that adhesion is inherently an interaction between surfaces that (on an atomic level) leaves neither unchanged, there's a case to be made that every adhesion is an alteration. On the other hand, plenty of other things (like simple contact) involve changes at that level, and wouldn't conventionally be called alterations.
FIRST would probably be concerned with the use of solvent-based adhesives on polymer substrates (high risk of error leading to failure, e.g. of a crazed pneumatic tank), or of installations that impose unforeseen loads (e.g. using epoxy to mechanically fasten a dynamic component to the side of a pneumatic cylinder). They probably wouldn't be concerned about masking tape holding a pneumatic tube out of the way, or about normal wear and tear incurred during a short working life. But the rules don't offer a specific basis upon which to distinguish these cases, so absent clarification from the usual official sources, it's going to come down to the officials at each event and their interpretation of the rule.
I think it will be hard to set and enforce a consistent standard using the rule as written, because alteration is easy to find if you're looking. If that's true, a rule update (possibly in the form of some more exceptions) would be preferable to a Q&A response (which can't change the fundamental constraint concerning the "original, unaltered condition").
Unread 06-02-2014, 14:09
Tristan, I am relating the standard rubric that inspectors are trained to make decisions in the field based on the rule and the inspection checklist.
____ No Modifications - pneumatic parts may not be modified except actuator mounting pins may be removed. <R76>
