Go to Post As long as the competition gets the attention of someone and drags them in, it doesn't matter how they get there. - Andy Grady [more]
Unread 05-02-2014, 16:24
sthreet's Avatar
sthreet sthreet is offline
AKA: scott threet
FRC #4692
sthreet is an unknown quantity at this point
on the dashboard, and lack of imports/declarations in tutorials
I'm wondering what I declare to use the dashboard?
Read this: http://wpilib.screenstepslive.com/s/...-robot-program
Didn't show what imports I use.
Also if I do dashboard.putNumber("string", 1); and then dashboard.putNumber("string", 2); will the 1 be replaced with a 2 or will there be two things onscreen?
And why do these tutorials not include all the imports/variable declarations for things, it makes me ask these questions that are probably asked every year about what they are.
Spoiler for gif:
Unread 05-02-2014, 17:46
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: on the dashboard, and lack of imports/declarations in tutorials
you don't need to initialize it on the robot, only on desktop. if you write the same key twice, the previous key gets overwritten and you only have 2 left.
You can write Boolean, Numeric, or String values to the SmartDashboard by simply calling the correct method for the type and including the name and the value of the data, no additional code is required. Any time in your program that you write another value with the same name, it appears in the same UI element on the screen on the driver station or development computer.
Unread 11-02-2014, 16:49
sthreet's Avatar
AKA: scott threet
FRC #4692
It still isn't working, variable "SmartDashboard" not found. Tried everything I could thing of similar to that.
Spoiler for gif:
Unread 11-02-2014, 16:57
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
It sounds like you don't have an import for the SmartDashboard in your code.
Unread 11-02-2014, 17:11
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
ctrl+shift+i
Unread 12-02-2014, 16:10
sthreet's Avatar
AKA: scott threet
FRC #4692
Thanks, that fixed it. Now I have it working. I will remember that trick for the future.
Spoiler for gif:
