Go to Post SWARF is evil! - Al Skierkiewicz [more]
Unread 05-02-2014, 14:34
Edxu's Avatar
Edxu Edxu is offline
Strategy/Scouting Mentor
AKA: Edwin Xu
FRC #4476 (W.A.F.F.L.E.S Robotics)
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
Two regulators for one piston
Hi CD,
We're wondering if it is legal to use two pressure regulators to actuate the extension and return strokes (A and B inputs) of a piston at different working pressures.
Thanks
Unread 05-02-2014, 14:41
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
Re: Two regulators for one piston
You can use flow control valve (the small fitting in KOP).
Unread 05-02-2014, 14:43
4.10.17 R90
The outputs from multiple valves may not be plumbed together.
Sorry.
Unread 05-02-2014, 14:50
Edxu's Avatar
AKA: Edwin Xu
We intend to use a regulator (lowering the pressure) after the solenoid, but only on one side. We cannot find anything in the rules that explicitly forbids this.
Unread 05-02-2014, 15:16
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
4.10.17 R90
Sorry.
Can I use two sets of regulator (say one at 60lb and one at 20lb), gauge and solenoid valves then select between the two sets with a third valve? The outputs of the first two valves would be connected to the inputs of the third. At no time are two outputs connected together and I can drive the cylinder with the third valve to either 60lb or 20lb.
Unread 05-02-2014, 15:24
FRC #1559
Originally Posted by Edxu View Post
Hi CD,
Thanks
Al,
I don't think the original question actually tied the outputs together. Are you sure this would not be legal?
Unread 05-02-2014, 15:54
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
There is also the other option: One valve for extension, the other for retraction.
Is that legal? The two feeds are separated by the disk in the cylinder and not tied together.
Unread 05-02-2014, 15:56
matthew_martin's Avatar
matthew_martin matthew_martin is offline
FRC #4265 (Secret City Wildbots)
Team Role: Communications
matthew_martin is an unknown quantity at this point
I think the best option would be to use Pressure Flow Regulators that are actually fittings that mount on the cylinders themselves. I know you can order then from AndyMark here: http://www.andymark.com/product-p/am-2032.htm
They look kinda like the things in the picture.
Unread 05-02-2014, 16:15
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
OP- you may consider spring returns added on, spring return cylinders, or a smaller cylinder to retract the whole mechanism if your idea doesn't pan out.
As I understand it one of the two solenoid outputs would have a regulator between the solenoid and the air cylinder. The outputs of one solenoid are connected to the air cylinder(s) and it would seem legal, in my non-expert opinion.
R90
Now... there are two ways to interpret this... either the outputs cannot be connected to the same cylinder, or they cannot be connected to the same port and/or tee-d together. Our resident expert, Al, interprets it as they cannot be connected to the same cylinder.
In 2010 that rule did not exist (as far as I know) and my team did exactly this, and it was inspected as legal.
The intent, I assume, is to reduce air usage, not to slow down the mechanism. I assume 610 is going to have an awesome air-powered shooter and they want to get more shots out of it in each match.
Unread 05-02-2014, 16:27
Edxu's Avatar
AKA: Edwin Xu
Thanks, this is what we were worried about.
Could anyone else confirm if that is illegal or not?
Unread 05-02-2014, 16:43
FRC #1559
I think your original post is legal, but Al is the CD rules guru (and a good one at that). Given the uniqueness of this, you may want to submit an official Q&A.
The way I interpret your question is:
-------------- portA
valve |
----2nd Reg -- portB
you only have one valve and its outputs are not connected together (other than through the piston, which is typical). So the real question is can you have a regulator after a valve (or can you have two working pressures). I don't see a rule that prevents this - and it should help you exhaust the air out of portB quicker.
Unread 05-02-2014, 17:16
Bob Steele's Avatar
AKA: Bob Steele
I don't see why this would be illegal. You are allowed to use regulators/accumulators anywhere you wish. You just have to have the mandated one that regulates the working pressure of your system down to 60 psi. Beyond that point you can have regulators anywhere you wish. Of course all they could accomplish would be to lower the pressure into a given cylinder or portion/stroke of a cylinder.
You are not plumbing the outputs of 2 solenoids to the same cylinder.
As always, your best bet is to ask in Q/A
Al may have misunderstood your initial question. His statement is entirely correct but it doesn't answer your specific question.
He is the Chief Robot Inspector... and not just a "Rules Guru" by the way
Last edited by Bob Steele : 05-02-2014 at 18:08. Reason: Wanted to get Al's title correct
Unread 05-02-2014, 17:56
If I understand this, you are using a third valve to select one of the set pressures? So the cylinder is connected to the common of the third valve? If that is the case, at first glance, I think it is legal and satisfies the pneumatics rules. I have been over ruled before so I can only suggest you ask the Q&A for the only valid answer.
I am only knowledgeable on the rules because it is what I am required to do as Chief Robot Inspector. All team members should read the rules.
Unread 06-02-2014, 01:13
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Matt could have shown the other side of the fitting which has the symbols for the flow control meter out valve on it. There is also a flow control meter in valve available. I'll try to attach pictures and symbols.
Name:	IMG_9621 flow fitting.jpg
ID:	16124  Click image for larger version
Name:	flow control meter out valve.jpg
ID:	16125  Click image for larger version
Name:	flow control meter in valve.jpg
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 06-02-2014, 09:06
FRC #1559
A flow control valve will do the opposite of what is desired. A flow control valve does not change the final pressure, but changes how fast the air can enter/leave the cylinder and therefor slows down the travel. He is trying to exhaust the air in the cylinder faster. Since we are limited by the diameter of the valve, he is trying to limit the pressure on the exhausting side, and therefor the amount of air that needs to be expelled. To move the piston, you need more pressure on one side than the other, which we do by venting one side - he is trying to start from a more favorable delta pressure.
