Re: solder a bracket to a brass pneumatic fitting?
As an Inspector, the soldering would definitely raise questions, and Epoxy would probably make me call the LRI (if I noticed it). I don't know enough about the possible chemical reactions between whatever form of epoxy used and brass to know if there is risk of compromise.
I'd also flunk that, also with epoxy.
You may not modify pneumatic parts. A famous vendor from Kokomo was reminded of that at Champs two years ago.
After I warned him!
Why would you flunk a fitting that has been glued in place?
Would VHB or a double-stick tape be okay in your opinion? |
Given that adhesion is inherently an interaction between surfaces that (on an atomic level) leaves neither unchanged, there's a case to be made that every adhesion is an alteration. On the other hand, plenty of other things (like simple contact) involve changes at that level, and wouldn't conventionally be called alterations. FIRST would probably be concerned with the use of solvent-based adhesives on polymer substrates (high risk of error leading to failure, e.g. of a crazed pneumatic tank), or of installations that impose unforeseen loads (e.g. using epoxy to mechanically fasten a dynamic component to the side of a pneumatic cylinder). They probably wouldn't be concerned about masking tape holding a pneumatic tube out of the way, or about normal wear and tear incurred during a short working life. But the rules don't offer a specific basis upon which to distinguish these cases, so absent clarification from the usual official sources, it's going to come down to the officials at each event and their interpretation of the rule. I think it will be hard to set and enforce a consistent standard using the rule as written, because alteration is easy to find if you're looking. If that's true, a rule update (possibly in the form of some more exceptions) would be preferable to a Q&A response (which can't change the fundamental constraint concerning the "original, unaltered condition"). |
#7
Tristan, I am relating the standard rubric that inspectors are trained to make decisions in the field based on the rule and the inspection checklist.
____ No Modifications - pneumatic parts may not be modified except actuator mounting pins may be removed. <R76> |
