Go to Post If they want my business, then they should act accordingly. If they don't, I am quite happy to take my business (and that of my $16.5 billion organization) elsewhere. - dlavery [more]
Unread 05-02-2014, 16:40
jeffreypaules jeffreypaules is offline
AKA: Jeff Paules
FRC #2521 (SERT)
jeffreypaules is an unknown quantity at this point
E09 Classmate Image Problem
We cannot get the 2014 Driver Station Image to install on our E09 Classmate. When we try to boot from the USB drive we prepped using RMPREPUSB we keep getting a message that bootmgr cannot be found. Any help appreciated.
Unread 05-02-2014, 16:46
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: E09 Classmate Image Problem
Look on the first web site, KOP page. There is a fix for this that involves rebuilding the memory stick
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 05-02-2014, 17:26
AKA: Jeff Paules
FRC #2521 (SERT)
Unfortunately that does not apply. We're using the new 030114 image, which is supposed to be fixed. I even looked over the DS file, and the code matches the correct file name, where the previous version had the error. But it never even gets as far as restoring the driver station, it dies in boot up.
I've looked at the USB. It shows a bootmgr file, but for some reason it doesn't seem to recognize it's there during restart.
Unread 07-02-2014, 01:24
AKA: Jeff Paules
FRC #2521 (SERT)
Problem Solved! RMPrepUSB loads all the files into a folder on the USB drive, NOT the root directory. Move all the files to root, and Bob's your uncle.
