Go to Post After all, each day is fresh with no mistakes in it [yet]. - atomikitten [more]
Unread 03-02-2014, 21:03
Sonicnine1 Sonicnine1 is offline
FRC #3781
Sonicnine1 is an unknown quantity at this point
Camera Problems
My Axis M1014 camera works when i connect to it by plugging the cord into the computer, but not in the CRio. Why doesn't it work? Help?
Unread 03-02-2014, 21:09
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Camera Problems
Have you configured the camera?
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 03-02-2014, 21:30
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Camera Problems
If you haven't, there are instructions here:
http://wpilib.screenstepslive.com/s/...an-axis-camera
Unread 04-02-2014, 00:47
FRC #3781
Re: Camera Problems
Yah,i did that, but it still didn't work
Unread 04-02-2014, 07:50
Re: Camera Problems
How are you trying to use the camera? If you are trying to communicate back to the dashboard, be sure to set the camera's IP address to 10.te.am.11. Make an FRC account with password of FRC. Turn on anonymous viewing. Then launch both the dashboard and the driver station. The DS needs to be setup with your team's number -- this is how the dashboard determines the camera IP address.
Greg McKaskle
Unread 04-02-2014, 13:21
Re: Camera Problems
What do you expect it to do? Telling us it "works" isn't enough information.
Please clarify what you mean by "in the CRio". Are you connecting the camera by an ethernet cable to the second network port of an 8-slot cRIO? Are you connecting it to one of the ports on the D-Link router? Are you doing something other than those two options?
Unread 04-02-2014, 21:42
FRC #3781
Re: Camera Problems
Sorry, i'm trying to make video on the Driver Station play.
Unread 05-02-2014, 07:58
Re: Camera Problems
Unread 05-02-2014, 16:20
FRC #3781
Re: Camera Problems
I tried configuring it both ways and it still didn't work
Unread 05-02-2014, 18:27
FRC #3781
Re: Camera Problems
I have no clue what I did, but I was messing around on the camera settings and it started working. I wish I knew what I did.
