Go to Post It means Dave Lavery isn't on the Game Design Committee this year. If he were, you probably would have found a banana instead. - Alan Anderson [more]
Unread 05-02-2014, 19:41
MechaKnight996 MechaKnight996 is offline
FRC #0996
MechaKnight996 is an unknown quantity at this point
Exclamation Need help on program please
Okay, so i am nearing completion of my code but I need to make a motor spin when i press a button on the joystick and I'm not sure how. If anyone can help please post a response.
Unread 05-02-2014, 19:46
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Need help on program please
Could you give us some more information? What language are you programming in? What motor controllers are you using? Can you post any portion of your code that you are having issues with?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 05-02-2014, 19:48
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
What language are you using?
In LV, you could do something like this:
Kettering Motorsports
Unread 05-02-2014, 19:51
FRC #0996
Im using labview, and i need it to run from a joystick button.
Unread 05-02-2014, 19:59
FRC #0996
Thank you for your help, it works now.
Unread 05-02-2014, 20:09
apalrd's Avatar
More Torque!
VRC #3333
No problem!
There are a lot of ways to do it (that is only one, but it's probably the easiest), but however you do it, you can only have one Set Motor for each motor in teleop, otherwise they will 'fight' with each other.
Unread 05-02-2014, 20:20
FRC #0996
how would i run 2 seprate motors?
Unread 05-02-2014, 20:23
apalrd's Avatar
More Torque!
VRC #3333
You would write separate code for each motor.
If you have more than one 'Set Motor' for a single motor, then the value will be set to both values, and one of them will 'win'. Which one exactly is random.
You can still have multiple 'Set Motor' calls in Teleop, as long as there is only one per motor.
