Go to Post Who needs weapons when you have a scary face - Conor Ryan [more]
Unread 05-02-2014, 20:41
Re: Xbox 360 controls will this work ?
Originally Posted by gerry View Post
what im trying to do is make like a "condition" per say. if button 5 is pressed relay 1 will move forward however if button 2 and button 5 are pressed relay 1 will move reverse
Just replace your button 5 with my button 2.
and your button 2 with my button 3, and you get exactly what you stated above.
if button 5 2 is pressed relay 1 will move forward however if button 2 3 and button 5 2 are pressed relay 1 will move reverse
Unread 05-02-2014, 21:19
gerry gerry is offline
FRC #4144
gerry is an unknown quantity at this point
alright now if i wanted two bring in another button to that same circumstance say button 6 then i would have if button 5 is pressed relay 1 will move reverse if button 5 and 2 is pressed then relay 1 will move forward now if button 6 is pressed relay 2 will move reverse and if button 2 and button 6 is pressed the relay 2 will move forward
using the same logic for circumstance 1 how will i wire the two outcomes of both circumstances two only one wiring point would io use a (and) function ?
Unread 05-02-2014, 21:47
Just have two separate decision trees for the two different relays.
Don't try to combine them if they don't have to be. That just makes the code confusing to understand.
Unread 05-02-2014, 22:16
FRC #4144
yes yes it does thanks for the help
