Go to Post Oh great, look what you just did. The GDC will probably find ways to use this to torture teams in 2011. I hope you're happy now. - synth3tk [more]
Unread 05-02-2014, 19:32
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Ethernet port on robot
Ok, so my electrical peeps have posed a question and before I say ok I would like to know if anyone else has tried this.
They want to mount an Ethernet port on the bot. The Ethernet cable on the backside would lead to a port on the cRio and be 'permanently' connected (i.e. there would be no need to plug and unplug this cable from the cRio).
The idea is that when the coders needed to upload code they would do so through this port instead of having to, 'reach inside the bot where there are sharp pointy things that can poke and scratch the coders' sensitive hands.'
I have searched CD and have not seen where anyone has done this and according to the peeps interpretation of the rules this would fall under a 'custom circuit'.
I have told them that I was first going to check CD and then post in Q&A before I would consent to their experiment.
Thoughts?
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 05-02-2014, 19:34
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: Ethernet port on robot
Thoughts?
Not sure if this is what you mean, but last year we ran an Ethernet "pigtail" (male to female) from our radio to an easily accessible spot for ease of access to a port. Worked quite well at competition.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 05-02-2014, 19:40
rsegrest's Avatar
Maybe...ok, I see what you're talking about (thank you Google). What they are actually talking about is the wall-jack itself (like you see in a wall where you plug in your Ethernet cable. In their minds they would physically wire the jack themselves with the RJ-45 end plugged into the cRio and the port available for plugging in the computer.
What you guys implemented is makes more sense logically.
~ Unknown
Unread 05-02-2014, 19:42
m1tche11d m1tche11d is offline
m1tche11d
FRC #1997
m1tche11d is an unknown quantity at this point
If you're concerned about it working properly: it should be fine. We've used similar setups for the same reason over the years, and they've worked well.
If you're concerned about rules: a) you won't be connecting from the ethernet port to a computer during competition unless you are changing code at competition. b) R56 says that the wireless bridge may be connected via a pigtail, which is what it sounds like you are using.
Either way, you should be fine.
Unread 05-02-2014, 19:46
rsegrest's Avatar
Thank you for the quick replies
~ Unknown
Unread 05-02-2014, 21:11
How would the radio be connected to the cRIO in this scenario?
Unread 05-02-2014, 21:34
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
you can have a spot where the pigtail is out of the robot. Ie what spectrum did in their drive train during the off season. This allows for an easy remove/install for the cable. See http://www.chiefdelphi.com/forums/sh...d.php?t=119581 they did what I think you are speaking of.
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 05-02-2014, 23:20
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
I would put the pigtail in the router if your using the crio II.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 05-02-2014, 23:55
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
I would recommend doing this not only on your robot but your driver station as well. That port gets frequent use and my team had actually experienced the Ethernet port on the laptop fail causing us not to move in a match. Here is a company associated with FRC that sells the one that we now use https://www.estoprobotics.com/estore...d&productId=27
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 06-02-2014, 00:16
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Agreed. We beat up our Classmate ethernet pretty badly, so when we got a new laptop, we made sure to use a pigtail for the connection.
There are enough things that can go wrong without worrying about the ethernet port...
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 06-02-2014, 00:35
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Can we have the radios on in the pits? I thought not but maybe that is an old rule. We always hook up a little 4-port bridge for pit access - that way we can hook up the cRIO, tether the DS and connect a code development laptop.
Unread 06-02-2014, 00:42
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
In 2012, we used one of these port savers to easily connect to the robot, since the ports all pointed down on the radio in a most-inconvenient way.
As to radios in the pits:
T2
Wireless ROBOT control is only permitted on the FIELD or Practice Field. ROBOTS must be operated by tether when outside the FIELD or Practice Field.
Unread 06-02-2014, 00:48
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
We've had an externally available port for a number of years. Typically we do it with a female-female connector designed to be mounted through a surface - just cut out an appropriate rectangle in one of the lexan shields, push it in until. It clicks in place, then hook it up permanently to the radio using a short Ethernet cable. The benefit of this over a wall jack is that you don't have to mess with the wiring - just use standard cables and it all works out. I hate cutting open an Ethernet cable and having to figure out where all 8 wires go!
2016: Lake Superior WFFA
Unread 06-02-2014, 01:39
You can have the D-Link powered on in the pit, as long as you leave it in Bridge mode and don't try switching it to AP mode. You are encouraged and expected to leave everything connected on the robot, and plug in your programming computer and/or Driver Station using an available D-Link ethernet port.
Unread 06-02-2014, 08:55
rsegrest's Avatar
Which is what we have typically done. I am not sure where they are talking about burying the router that this is necessary (we have not fully discussed their reasoning yet as they proposed this close to time to go home last night). They just kept saying, 'but it would be soooo much safer'.
Thank you to everyone who responded and we will take your suggestions under advisement.
~ Unknown
