Go to Post My guess is you all are planning on being overweight......interesting strategy.....i like it - Stephen Kowski [more]
Unread 05-02-2014, 13:27
DampRobot's Avatar
Physics Major
AKA: Roger Romani
pic: Team 100 Drivetrain In Progress
Unread 05-02-2014, 13:28
MelodyPond MelodyPond is offline
AKA: Sydney Buckner
FRC #4265 (The Wildbots - Team 4265)
MelodyPond is on a distinguished road
Re: pic: Team 100 Drivetrain In Progress
So many CIMS! Looks good!
Sydney Buckner
Project Manager - The Wildbots Team 4265
"Passionately pursuing perfection in order to obtain excellence."
Unread 05-02-2014, 14:21
Answer42's Avatar
Answer42 Answer42 is offline
Answer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud of
Slick. I like the black top rivets. Are you going to have to cut that middle shaft to fit it inside the frame perimeter?
My comments do not reflect the views of associated teams.
Unread 05-02-2014, 16:45
Andrew Lawrence
Posts: n/a
I spy omni wheels...
Unread 05-02-2014, 17:57
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Those CIMs are awfully close together.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 05-02-2014, 18:44
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Yep. We did it a few days after that picture was taken, just hack sawed the shafts off. And we're huge fans of the black rivets too.
Yep. We like the ease of turning that they buy us, and their anti-defense qualities. It's a ton easier to T-bone pin a robot with all traction than with omnis. We'd rather slide out of the way and keep driving than have us locked up by defense for 30 seconds.
True dat.
-Plutarch
Unread 06-02-2014, 02:35
iyermihir iyermihir is offline
FRC #0649 (Saratoga MSET)
Team Role: CAD
iyermihir has a spectacular aura aboutiyermihir has a spectacular aura about
Have you actually tested this and found it to be true with your current wheel setup? I do not see how this would turn any better than a drop center with all traction wheels. Your traction wheelbase touching the ground is the same in both cases.
Also, I can see how the omni wheels will help you avoid T-bone situations if you are being contacted between the center traction wheels and the end of the robot with omni wheels, but you will be just as T-boneable from the section of your robot between the center wheel and the end of the side with traction wheels.
Why did you decide to include the middle wheel? Having just four wheels with one end omni and the other traction would let you turn better and make you almost impossible to T-bone.
-Mihir Iyer
Unread 06-02-2014, 03:02
DampRobot's Avatar
Physics Major
AKA: Roger Romani
-Mihir Iyer
It turns out that our drivetrain this year is actually really similar to our 2011 drive. That year, we had 6 4" AM performance wheels with roughtop, and found that even with drop center, the robot had a bit of difficulty turning on carpet. Even though the CG was firmly to the back off dropped center, the front wheels still scrubbed while turning. While experimenting before CalGames of that year, we found switching two wheels to omnis really improved turning performance, as they reduced the amount of lateral friction even in wheels which were nominally not contacting the ground. We turned a ton better with 4 traction 2 omni than we did with 6 traction.
One dirty secret about 6wds is that despite the drop center, all 6 wheels still contact the ground, just to varying degrees. Depending on your total mass, wheel type, and center of gravity, you'll just put different amounts of force on each wheel, and engage the carpet at that wheel more or less. Unless you have some totally crazy center drop, your other wheels will still contact the carpet to some degree. The center drop just keeps you from really digging in the farthest out wheels at the same time, which would percent you from turning.
In any case, the WCD VersaChassis makes it super easy to switch out wheels. We can literally switch between any combination of omnis/versa wheel/versa wheel DT/rough top in about ten minutes. If we figure out that we don't like the omnis, we won't use them. We could also go all omnis is we wanted to. The setup seen in that photo is our best guess for the best wheel configuration for this game, given our teams past experiences, and from observing other teams drivetrains. I think we'll play around with the wheel configuration after seeing how the robot handles on carpet and interacts with defense.
Hopefully I've answered your questions to satisfaction. I love talking about this stuff, so if you'd like to hear more, I'd be more than happy to oblige.
-Plutarch
