Go to Post You have accomplished and learned more in the past six weeks than...a majority of people in the country. Be proud of your machine. Don't kick it to the gutter. Stand behind it. Believe in it. Give it your all. Take pride in your robot. :) - sanddrag [more]
Unread 06-02-2014, 10:06
Nate Laverdure's Avatar
FRC #2363
pic: It's systems integration time!
Unread 06-02-2014, 10:11
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
Re: pic: It's systems integration time!
That is really clever. It's amazing how such a simple thing can make you so happy.
One valve that I found a few years back is McMaster 6790T42
http://www.mcmaster.com/#catalog/120/481/=qkrfx0
Under Brass push button valves. With a normally closed action, you'll never have to remember to close the valve again. I think this would still work well with your mounting method.
Unread 06-02-2014, 10:51
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
That's really cool. I love the idea of using a spring loaded valve for the dump valve. I hope that someday they will become legal to use.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 06-02-2014, 11:14
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
We've used the part Jake mentioned for the last couple years with no issue.
2012-2016 Wave Robotics Team 2826
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Why are they illegal now?
They meet all the requirements of R89.
Kettering Motorsports
Unread 06-02-2014, 12:20
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
It violates R77.B:
"The only pneumatic system items permitted on 2014 FRC ROBOTS include the items listed below. ...
B: Pneumatic pressure vent plug valves functionally equivalent to those provided in the KOP."
A momentary push button electrical switch is not functionally equivalent to a toggle switch, which must be actuated in both directions.
A spring-loaded single-acting pneumatic cylinder is not functionally equivalent to a double acting pneumatic cylinder, as it returns to its retracted position without actuation.
A spring loaded push button pneumatic valve is not functionally equivalent to a rotational ball valve, which must be actuated in both directions. For the purposes of a dump valve in a FIRST robot, the functionality of being spring loaded makes it better than a ball valve. From an air flow perspective, they may flow the same, just as electricity doesn't care whether it is switched by flipping a switch or pushing a button. But, to the operator, they are very different. If it were functionally equivalent, there would be no reason to use it. (Other than cost and availability.)
I suggest a question to Q/A. I'd love for them to rule the push button dump valves legal.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 06-02-2014, 12:29
It violates R77.B:
A spring loaded push button pneumatic valve is not functionally equivalent to a rotational ball valve, which must be actuated in both directions. For the purposes of a dump valve in a FIRST robot, the functionality of being spring loaded makes it better than a ball valve. If it were functionally equivalent, there would be no reason to use it. (Other than cost and availability.) From an air flow perspective, they may flow the same, just as electricity doesn't care whether it is switched by flipping a switch or pushing a button. But, to the operator, they are very different.
Do they both not serve the same function? They both allow and prevent the release of air pressure.
Unread 06-02-2014, 12:32
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
One allows you to forget, and leave it permanently open. The other does not. They are not functionally equivalent.
If one component includes a function which differentiates it from another, and makes it more desirable for a particular application, by definition, they are not equivalent.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 06-02-2014, 13:06
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
1. Any valve can be forgotten about and be left open or closed so I dont see the difference there.
2. No they are not equivalent but they are FUNCTIONALLY equivalent. They serve the same purpose via slightly different methods. More than one compressor is leagal for first. They are both FUNCTIONALLY equivalent but they certainly are not the same one is heavier and can be viewed as a disadvantage.
Unread 06-02-2014, 13:10
AGPapa's Avatar
AGPapa AGPapa is offline
AKA: Antonio Papa
FRC #5895
AGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond repute
No, the valve that Jake linked to (the one we're discussing) closes by itself.
Team 2590 Student [2011-2014]
Team 5684 Mentor [2015]
Team 5895 Mentor [2016-]
Unread 06-02-2014, 13:21
apalrd's Avatar
More Torque!
VRC #3333
Guys, you're over analyzing this.
A manual valve is a valve, it releases the pressure in the system when manually actuated. IMHO, the function is to release pressure when actuated manually, and both valves do that.
Not sure why we have to read so hard into this.
Unread 06-02-2014, 13:35
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
R77B does not apply to compressors.
See R77J and R79.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 06-02-2014, 13:47
amesmich's Avatar
FRC #4638 (Jagbots)
See R77J and R79.
I realize that I was making a general point of functional difference.
I didnt realize the valved closed by itself. I agree with the above post, reading too much into it.
Unread 10-02-2014, 11:22
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
I'm concerned with whether spring loaded push button valves are legal because there are some really cool things that can be done with them. This year there is no rule that says pneumatic cylinders must be actuated by solenoid valves.
For example, a small pneumatic cylinder actuated by a legal solenoid valve could be used to push the button on a high flow spring loaded push button valve (McMaster 6859K31 for example) that fires a pneumatic catapult.
Another example would be a weight which is held up by a motor that has power as long as the robot is operating. In case of a dead robot, the weight drops on a push button valve, which ejects the ball from the robot.
edit: Never mind. Just found Q235.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 10-02-2014, 11:28
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
Actually, the Q&A already dealt with the alternate uses of manual valves (Q235). You are only allowed one, and it can only be used to vent pressure for the system.
