Go to Post - Only think of Gracious Professionalism as a standard to work toward personally. - Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Unread 06-02-2014, 12:53
jls667 jls667 is offline
None #2579
jls667 is an unknown quantity at this point
Re: Axis Camera video feed in Java
I think that I need more of an explanation how to access my camera during competition. The camera is configured to the correct IP address and plugged into the bridge.
Unread 06-02-2014, 12:58
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Which dashboard are you using on your driver station? Smart Dashboard? Default? What is the IP address that your camera is configured to?
Unread 06-02-2014, 15:51
None #2579
I think the default dashboard. How come when I click on Java the dashboard disappears leaving only the drivers station?
Unread 06-02-2014, 20:41
DCRich DCRich is offline
FRC #2180 (Zero Gravity)
DCRich is an unknown quantity at this point
The default is the Labview dashboard. When you click on Java you are telling the driver station to use the Smartdashboard, which you have not yet installed so everthing goes away.
There is a section in Getting Started with Java 2014 that points to using the SmartDasboard. This is what was used in the videos on Command Based Java programming
Unread 07-02-2014, 07:53
Flywheel Police
If you leave it as default and you toggle the camera switch on the screen next to where the camera feed should show up do you see the feed?
Unread 07-02-2014, 18:51
None #2579
Does is mean I do not need to add any Java code to see the camera during competition?
