Go to Post You can never be done too early for more testing and practice! - Donut [more]
Unread 06-02-2014, 15:42
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Team 935 autonomous testing
Originally Posted by railerobotics View Post
The rule you are referencing (G28) does say that contact that is deliberate or damaging will be penalized. Excluding damage, there is a gray area of whether or not our contact was deliberate. Is the act of our robot shooting and a defense bot being struck deliberate contact on our part? We would be deliberately shooting the ball, not attempting to contact the defense bot. However I agree, that if we do cause damage we will probably be penalized, however the cylinders pushing out the arms are not forceful in any way. They only have the strength pull the arm in and out. They can be held up with merely an outstretched arm. Thus they will not be damaging unless we hit electronics (which is quite unlikely).
That's good that the mechanism is so forgiving, that should buy you a lot of latitude. I guess the only thing to really worry about is a defender stopping you from opening it in the first place!
Unread 06-02-2014, 15:46
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Yup and only one solution for that.
Practice. Practice. Practice.
Inspiration of Today,
Technology of Tomorrow.
Team 935
http://www.team935.com
Unread 06-02-2014, 16:02
smart1's Avatar
smart1 smart1 is offline
AKA: Kyle
FRC #0967 (Iron Lions)
smart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud of
wow that's impressive.
Who is this guy named We I keep hearing about, everybody says We will do that later but I haven't ever met him.
Unread 06-02-2014, 17:00
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
We were also thinking of a 2 mode autonomous mode
Also, is that a Haas CNC machine in the back? Very nice
Unread 06-02-2014, 17:10
FRC #0935
Yes it is, our team has been very fortunate in our high school partnering with a local community college. Because the community college has machining classes on our campus we are able to take full advantage of two CNC mills and two CNC lathes, as well as a multitude of manual machines. This also allows us to machine out every part of our robot, fixing mistakes as we progress through building it. And trust me, there are A LOT of mistakes. , but that is what robotics is about, learning how to fail, and learning from failing.
Team 935
Unread 06-02-2014, 18:24
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
What about "lit" goal detection? We haven't test (or considered) auto yet, but we're most likely going to have a "wait to shoot" feature to get extra points if our goal isn't lit.
Unread 06-02-2014, 19:19
FRC #0935
We decided the extra 5 points we would get was not worth (most likely) not getting 2 shots off. It was much simpler to just time the program to be sure to get the goal when it is hot at least once. The first shot goes in during the first 3 seconds and the second at 9 seconds. So we will get the hot goal at least once.
Team 935
Unread 06-02-2014, 18:27
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Very nice - simple, repeatable, reliable! Do you use a sonar to measure the distance from the wall?
Unread 06-02-2014, 18:48
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Good luck this season guys!
Unread 06-02-2014, 19:20
FRC #0935
Nope it is all just dead reckoning. Battery voltage and power levels were initially a concern, but we will have a charged battery on the board each time and even when the voltage did drop the results were not effected negatively.
Team 935
Unread 06-02-2014, 19:30
Dead reckoning using time as the only feedback?
Unread 06-02-2014, 19:33
FRC #0935
Yup. The plan is to put encoders on eventually, but we could not make the brackets this week and we wanted to test it and get it to work.
Team 935
Unread 07-02-2014, 01:34
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Great job guys. Have you considered how much air the multiple cylinders you are using will require and how frequently your compressor will likely need to run if you shoot x number of times per match? Looks like you might need more than 4 accumulators for sure.
"A genius is just a talented person who does his homework" T. Edison
Unread 07-02-2014, 04:00
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
I predict we will see a lot of these type of robots with 2 ball autons with the exception of those that will flip the ball over their head shooters, opposite intake collectors.
Unread 07-02-2014, 06:44
FRC #0935
We actually have 7 tucked away on there. we can get about 10 consecutive cycles with no recharge time before we need to stop and wait.
Team 935
