Go to Post No, Dave says "that's PUMP" - dlavery [more]
Unread 06-02-2014, 16:09
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Is this a legal bumper config?
There's no requirement that bumpers cover your frame... however, bumpers " must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame (e.g. not attached with hook-and-loop or tie-wraps). The attachment system must be designed to withstand vigorous game play." It is in your best interest to ensure there is sufficient support behind the bumpers that they will not come off - mounting them with some 1" angle where the only support behind the bumper is that 1/2" worth of frame would probably not be a robust connection - one good hit near the top of the bumper and it would bend/break off.
2016: Lake Superior WFFA
Unread 06-02-2014, 17:30
Bob Steele's Avatar
AKA: Bob Steele
Just a word of warning .... legal or not...
High bumpers can cause some real issues during gameplay.
Most robots will have low bumpers...
I am sure some other teams on CD can discuss the implications of really high bumpers during game contact....
Unread 06-02-2014, 20:13
GaryVoshol's Avatar
Cogito ergo arbitro
And don't forget the new rule this year, if your bumpers go out of compliance (e.g. become loose and sag below 2") you get disabled. Ugg.
(since 2004)
Unread 06-02-2014, 21:19
DonRotolo's Avatar
Back to humble
FRC #0832
Also, please bear in mind the vast difference between "frame" and "FRAME PERIMETER". The latter is very specifically defined, and that's what you MUST protect with BUMPERS, not the "frame" of your robot.
Unread 07-02-2014, 12:22
tavar321 tavar321 is offline
FRC #1389
tavar321 will become famous soon enough
@DonRotolo - Does that necessarily mean completely covered though?
Currently the bumpers are planned to mount with C-Channel attachments that are then pinned to the 16th" seen in the photo. We can also (and probably will) move the bumper down 1/2". I'm inexperienced with bumpers, so I don't know if these combined supports would be enough.
@John - We're using 2 pieces of C-Chanel connected to the 16th inch by 2 aluminum pin connectors each, would this fall into the 1" angle you meant? I would assume they could take some sheer stress, though not to large.
Unread 07-02-2014, 12:58
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
@tavar321
Your frame perimeter is all that matters for this rule. Your actual frame can be exposed above or below the bumper zone.
Judging by your photo (and assuming your bumpers are the legal size and weight), you are legal with regard to the bumper height. Since you did not show your whole bumper or frame perimeter (e.g., cutouts in the frame or how far your bumpers cover each corner), I cannot tell if you are 100% legal.
If you intend to have full coverage of your frame in accordance to the rules, then your bumpers, as shown, would be legal.
Can you do a simple sketch to explain how the C-channel will pin to the 1/16" metal?
