Go to Post ...when you hear a kid say "oink oink" and you say in your head "BOOM!" - delsaner [more]
Unread 05-02-2014, 21:14
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Is this a legal bumper config?
Had a quick question with our bumpers..
We're having a WCD this year and found that it was too low to the ground to mount bumpers. We could space up the bumper and attach it to the drivetrain frame but were wondering if the following was legal:
We have a mezzanine attached to the top of the drivetrain frame as a support structure to mount all of our stuff.. would it be legal to mount our bumpers to this mezzanine?
That is to say, is it OK to mount the bumpers to some upper support structure rather than the drivetrain frame? Is the "FRAME PERIMETER" the drivetrain perimeter or can it be the perimeter of the mezzanine? (which are the same)
Here's a picture to show what I mean.
You can see a side view of the WCD, with two channels at each end that are vertical and a horizontal bar (this is the mezzanine). The blue represents a bumper mounted to the mezzanine channel.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 05-02-2014, 21:16
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: Is this a legal bumper config?
As long as the bumper is below 10 inches and above 2 inches you should be fine. Your bumper doesn't have to mount off of your drive base.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 05-02-2014, 21:25
ksafin's Avatar
AKA: Kirill Safin
Awesome, just wanted to make sure. Thanks.
Unread 05-02-2014, 21:26
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
If the bumpers are true-to-drawing, The would be illegal as the corners in front/back are not protected. Like jblay said, as long as they are entirely within 2-10" of height, it does not matter what they are mounted to, provided that the mount is sturdy enough to take the impact of robots.
If you are planning high bumpers, I would personally advise against doing so if at all possible. This is due to the phenomenon where in a pushing match, the robot with the high bumpers tends to ride up on top of the bumpers of the low bumper robot, transferring a small but significant amount of your weight to their wheels, giving them more traction and yourself less (f=uN)
Unread 05-02-2014, 21:37
jblay's Avatar
AKA: Joe Blay
You have to make sure that your corners are covered yes. It can be the lower or upper bumper that covers the corner, but one of them has to.
Unread 05-02-2014, 21:56
GaryVoshol's Avatar
Cogito ergo arbitro
Your Frame Perimeter is defined by the outermost points of your Robot, located between 2 and 10 inches off the ground. If your "mezzanine" is the outermost part of your Robot, and it's located no more than 10" off the floor, it defines your Frame Perimeter and that's where your Bumpers must be attached. If another part of your Robot is wider, then that wider part is where the Bumpers must go. You could also use properly spaced stand-offs attached to your mezzanine to define your Frame Perimeter.
(since 2004)
Unread 06-02-2014, 15:42
tavar321 tavar321 is offline
FRC #1389
tavar321 will become famous soon enough
Adding on a very similar question: Does the bumper necessarily have to cover the frame element or could it just be attached to the frame member?
For context: the bumper zone is between 2" and 10," the base of our frame is 1.5" off the ground (up to 2.5"). We were thinking of attaching bumpers to the top of the frame, but not necessarily covering the 1" frame.
See the picture below for a picture with measurements, the plywood represents where the bumper would be.
Unread 06-02-2014, 16:09
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
There's no requirement that bumpers cover your frame... however, bumpers " must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame (e.g. not attached with hook-and-loop or tie-wraps). The attachment system must be designed to withstand vigorous game play." It is in your best interest to ensure there is sufficient support behind the bumpers that they will not come off - mounting them with some 1" angle where the only support behind the bumper is that 1/2" worth of frame would probably not be a robust connection - one good hit near the top of the bumper and it would bend/break off.
2016: Lake Superior WFFA
Unread 06-02-2014, 17:30
Bob Steele's Avatar
AKA: Bob Steele
Just a word of warning .... legal or not...
High bumpers can cause some real issues during gameplay.
Most robots will have low bumpers...
I am sure some other teams on CD can discuss the implications of really high bumpers during game contact....
Unread 06-02-2014, 20:13
GaryVoshol's Avatar
Cogito ergo arbitro
And don't forget the new rule this year, if your bumpers go out of compliance (e.g. become loose and sag below 2") you get disabled. Ugg.
(since 2004)
Unread 06-02-2014, 21:19
DonRotolo's Avatar
Back to humble
FRC #0832
Also, please bear in mind the vast difference between "frame" and "FRAME PERIMETER". The latter is very specifically defined, and that's what you MUST protect with BUMPERS, not the "frame" of your robot.
Unread 07-02-2014, 12:22
FRC #1389
@DonRotolo - Does that necessarily mean completely covered though?
Currently the bumpers are planned to mount with C-Channel attachments that are then pinned to the 16th" seen in the photo. We can also (and probably will) move the bumper down 1/2". I'm inexperienced with bumpers, so I don't know if these combined supports would be enough.
@John - We're using 2 pieces of C-Chanel connected to the 16th inch by 2 aluminum pin connectors each, would this fall into the 1" angle you meant? I would assume they could take some sheer stress, though not to large.
Unread 07-02-2014, 12:58
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
@tavar321
Your frame perimeter is all that matters for this rule. Your actual frame can be exposed above or below the bumper zone.
Judging by your photo (and assuming your bumpers are the legal size and weight), you are legal with regard to the bumper height. Since you did not show your whole bumper or frame perimeter (e.g., cutouts in the frame or how far your bumpers cover each corner), I cannot tell if you are 100% legal.
If you intend to have full coverage of your frame in accordance to the rules, then your bumpers, as shown, would be legal.
Can you do a simple sketch to explain how the C-channel will pin to the 1/16" metal?
