| Thread Tools |
Rating:
Display Modes |
#16
Re: Team 935 autonomous testing
What about "lit" goal detection? We haven't test (or considered) auto yet, but we're most likely going to have a "wait to shoot" feature to get extra points if our goal isn't lit.
#17
Very nice - simple, repeatable, reliable! Do you use a sonar to measure the distance from the wall?
#18
Good luck this season guys!
#19
We decided the extra 5 points we would get was not worth (most likely) not getting 2 shots off. It was much simpler to just time the program to be sure to get the goal when it is hot at least once. The first shot goes in during the first 3 seconds and the second at 9 seconds. So we will get the hot goal at least once.
#20
Nope it is all just dead reckoning. Battery voltage and power levels were initially a concern, but we will have a charged battery on the board each time and even when the voltage did drop the results were not effected negatively.
#21
Dead reckoning using time as the only feedback?
#22
Yup. The plan is to put encoders on eventually, but we could not make the brackets this week and we wanted to test it and get it to work.
#23
Great job guys. Have you considered how much air the multiple cylinders you are using will require and how frequently your compressor will likely need to run if you shoot x number of times per match? Looks like you might need more than 4 accumulators for sure.
#24
I predict we will see a lot of these type of robots with 2 ball autons with the exception of those that will flip the ball over their head shooters, opposite intake collectors.
#25
we can get about 10 consecutive cycles with no recharge time before we need to stop and wait. |
#26
Have you tested picking up both balls at the start? Leave the first ball ready to fire and holding the second ball in your intake? This could cut several seconds off your time and increase reliability.
#27
I was originally unsure if this is legal, but after looking around a bit I found this in the Q&A section: Quote:
#28
Very nice! I especially like you'r pick up/catching device.
#30
How many cylinders are you guys using to launch the ball? Hard to tell but it looks like 4
