Go to Post Robots that don't obey the laws of physics will be checked for alien technology and magic. - Greg McKaskle [more]
Unread 10-01-2002, 20:57
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I don't know of any coupler that slips over this gear but I suppose that you could find a Ruland coupler that would hold the 2.2 N-m that this motor puts out.
You could have one made by a wire EDM source. You have the gear data. Just have them make a hole the size of the gear in something that would be more to your liking (e.g. a larger more standard gear.).
As to side loads, the motor is intended to work on that small radius of that teenie gear. I suppose that it is pretty good in side loading conditions as long as you don't go too crazy.
Good Luck.
Joe J.
drill motor gear noise arshacker Motors 2 04-02-2003 19:52
Black motor mating gear mnkysp6353 Motors 5 20-01-2002 11:09
the motor mount with gear switch newatthis General Forum 4 15-01-2002 22:07
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
