Go to Post Truly listening to the wealth of advice around you is so important. Don't work in a vacuum all season long. - OZ_341 [more]
Unread 07-02-2014, 00:12
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
FESTO solenoid connectors
My team didn't get the connectors that connect the 1/8" tubing to the approx 5mm opening on our FESTO double acting solenoid valve. Does anyone know what it's called and it's dimensions? Also where would it be available?
While I'm at it, do we need a SPIKE(motor controller?) to control the solenoids?
One more question, do we need to have one solenoid breakout on the CRIO per solenoid valve?
Unread 07-02-2014, 00:18
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Re: FESTO solenoid connectors
If they are 12 volt solenoids then you could use a spike, but I am guessing that you have 24 volt ones. If they are 24 volt then you can use the solenoid breakout to control multiple solenoids.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 07-02-2014, 00:19
FRC #4733
They're 24 volts. Thanks!
Unread 07-02-2014, 00:24
AKA: Voltonless
FRC #3260 (SHARP)
Also this may be what you are looking for http://www.andymark.com/product-p/am-2384.htm
Team SHARP
Unread 07-02-2014, 00:30
FRC #4733
That's probably it. It's out of stock on AndyMarks. Would this be available in say a hardware store?
Unread 07-02-2014, 00:40
AKA: Voltonless
FRC #3260 (SHARP)
I dont think they would sell them at a hardware store, but here is another place that sells them http://www.alliedelec.com/search/pro...x?SKU=70070890, but check to make sure that it is correct for your needs. If you want to find somewhere else that sells them try searching for "m5 pneumatic 1/4 fitting" or something similar.
Team SHARP
Unread 07-02-2014, 07:58
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Take a look at the number on your valve. If the part number has an M7 in it, then you want the M7 fittings from AndyMark. The ones from FIRST Choice have M7 ports; at least, the ones we got are M7.
Unread 07-02-2014, 13:46
Maximillian's Avatar
Maximillian Maximillian is offline
AKA: Max Westwater
FRC #5254 (HYPE)
Maximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant future
First Choice had both M7 and M5 versions. The ones my team got were the 24V M5's.
Unread 07-02-2014, 16:22
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
You can order the parts from any Festo distributor. You can find distributors from the Festo website. I found one local to us in eastern MA. Even if the distributor is not local, Festo can sip direct to you. I believe there is a $25 handling fee for this (on top of the shipping charge).
