Go to Post What's the point of competing if you're not going to be competitive? - davepowers [more]
Unread 02-05-2014, 11:18 PM
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
String parsing missing.
I just attempted to mess with strings and have noticed that a lot of standard string functions are missing, such as replace all, split, etc. Is there a reason strings have heavily reduced functionality with the robot templates? More importantly, is there a way to get that functionality back? I noticed that regular java projects have a libraries folder with JDK inside, and the templates don't. Is this the culprit?
Unread 02-05-2014, 11:30 PM
Re: String parsing missing.
FRC robot programs use the Squawk JVM which is a derivative of a pretty old version of Java ME. This results in a lot of missing classes or functions you may be used to from using Java SE on the desktop.
Unread 02-05-2014, 11:33 PM
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
The JVM that runs on the cRIO doesn't have all the niceties that Java SE has (what's running on your desktop). We run on a version of Java ME.
You can write your own utilities functions to perform string operations.
Example string split function
http://team2168.org
Unread 02-06-2014, 12:37 AM
The 2015 control system will be using Java SE Embedded, so it will have the things you're missing.
Unread 02-07-2014, 08:01 AM
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Having to use an old version of java drives me crazy, the lack of ENUMS and other commonly used tools gets frustrating after a while. I'm glad to hear that we'll be upgrading next year.
