Go to Post I guess my point is, let's see how it plays out before we condemn it to failure. - Chris Hibner [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 02-06-2014, 07:57 PM
droswell's Avatar
droswell droswell is offline
FRC #2370 (iBots)
droswell will become famous soon enoughdroswell will become famous soon enough
Hinged Bumpers?
We'd like to hinge together several bumper sections for easy removal and changing. It seems like it's legal to me, but our team is on the fence. Rules say no actuation, does a hinge multipart bumper count, or is it legal?
Unread 02-06-2014, 08:26 PM
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
FRC #1058 (PVC Pirates)
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
Re: Hinged Bumpers?
I think as long as nothing moves during a match you will be ok. Many teams make one-piece bumper assemblies that go around the robot.
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
Unread 02-06-2014, 09:14 PM
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Hinged Bumpers?
Read the rules very, very carefully. If you do not find anything you are violating, then you are good to go.
I, personally, would not use hinges, but if that's the only way you see to solve the problem, and you cannot find a rule you are violating, go ahead. Just be sure to be ready to back that up at inspection.
Unread 02-06-2014, 10:30 PM
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Rynocorn is on a distinguished road
Re: Hinged Bumpers?
No way! We built some prototype bumpers with hinges and grab catches for testing. However, we ended up not using them because we were worried about them being illegal and didn't want to bother
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
Unread 02-07-2014, 08:53 AM
wilhitern1's Avatar
wilhitern1 wilhitern1 is offline
Sr. Systems Analyst / BRM
AKA: Neal Wilhite
FRC #1225 (Gorillas)
wilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to all
Re: Hinged Bumpers?
We've had hinges (back when I worked with 3737). But we also had vertical bolts and wing nuts at regular intervals to guarantee hard attachment. Previous year and potentially different venue is no guarantee of success this year.
Neal
Unread 02-07-2014, 11:00 AM
!Alp!
Posts: n/a
Re: Hinged Bumpers?
This is actually a pretty sweet idea, i would make sure though that it is secured very carefully during a match
Unread 02-07-2014, 01:17 PM
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: Hinged Bumpers?
We have designed our bumpers with door hinges at the inside corner, reversed from their normal position, allowing the plywood to reach each corner. We are using them so that we have a little flexibility to reach our C-shaped bumpers around the edge to fit for attachment. The hinges are quite rigid, much more so than screws, glue or most of the corner-building methods we've used or seen in the past. Once attached to their mounting points on the frame, the bumpers are extremely rigid.
