Go to Post Just once I'd love to see a team come out to the field and say " Team xxxx rejects our reality and accepts yours!" - Koko Ed [more]
Unread 07-02-2014, 09:34
Ted Andkilde Ted Andkilde is offline
FRC #4936
Ted Andkilde is an unknown quantity at this point
Is this Legal? Magnetic A/C clutch, AndyMark gearmotor combo
Hi guys
I'm a mentor on 4936, a rookie team from Tecumseh Ontario.
We're trying to finalize our mechanical today and I was hoping someone might be able to give me a quick legal/not-legal ruling on our winching rig.
It's an AndyMark gearmotor linked to the 12v clutch from a A/C compressor.
Ignore the wiring, it's just "make it function" stuff, it'll all be rewired with relays and limit switches.
Thanks, Ted
Unread 07-02-2014, 09:40
protoserge's Avatar
protoserge protoserge is online now
AKA: Some call me... Tim?
Re: Is this Legal? Magnetic A/C clutch, AndyMark gearmotor combo
Are you electrically actuating the clutch or are you just using the setup as a pure mechanical system? R29 should answer your question.
Unread 07-02-2014, 09:41
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
In the grant scheme not sure, but i know you have to set it up so that your not grounding to the big hunk of car.
i'm rooting for you great use of found parts!
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 07-02-2014, 09:43
FRC #4936
You have to supply/remove 12v to the clutch to lock/unlock the pulley to the shaft.
Cheers, Ted
Unread 07-02-2014, 09:47
FRC #4936
I'm just going to try to ping him, does @R29 work to notify on this message board?
Thanks, Ted
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Q&A 144:
Q. Are electric clutches allowed? And if so, can they be run from the solenoid breakout card since they are essentially a fancy solenoid?
A. An electric clutch is considered a solenoid actuator, and thus limited by R29.
https://frc-qa.usfirst.org/Question/...fancy-solenoid
2016: Lake Superior WFFA
Unread 07-02-2014, 09:50
protoserge's Avatar
Originally Posted by Jon Stratis View Post
Beat me to it! That's the only limitation I would see from R29.
The other is R11. Is this part considered COTS? And, if so, does it fall under $400? I am going to look some more to see if I can find something regarding automotive parts reuse. if you can price up the part number
EDIT: I don't have access to the black tote automotive parts recycling product donation voucher. See if it has any wording on this type of item. It may only cover motors, though.
I did find this to be a Volvo S40 compressor, and found one source for a price of $490 for a new unit
Thanks, Ted
I just check my User CP every once in a while for updates to threads.
Unread 07-02-2014, 09:54
FRC #4936
Thanks Jon
Unread 07-02-2014, 09:55
FRC #4936
It's a junkyard item, owes me $10.
Cheers, Ted
Unread 07-02-2014, 09:57
oh, and the applicable portion of R29:
Electrical solenoid actuators, no greater than 1 in. stroke and rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC)
You will need to bring in and provide a datasheet for the clutch that specifies stroke and input power.
Unread 07-02-2014, 10:02
Jim Wilks Jim Wilks is online now
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
I seriously doubt this solenoid is 10w or less.
Jim
Unread 07-02-2014, 10:04
FRC #4936
Hmmn, this could be a problem.
Google is all over the map on expected amperage draw for A/C clutches. everything from 0.75A to the teens...
Unread 07-02-2014, 10:05
Electrical Engineer
AKA: Jim Wilks
How about measuring it?
Jim
Unread 07-02-2014, 10:07
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
You could try measuring it yourself, but I don't think that counts for anything. The inspector will want hard documentation from the manufacturer.
Unread 07-02-2014, 10:22
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I don't think it is legal. It have to be a solenoid @ less than 10 W. Hard to document. It would not fall under the Automotive recyclers PDV since it is not a motor.
It should be though based on it being a really cool idea nicely done.
