Go to Post Ok, according to this, I am a hacker...Now will someone please come fix my computer??? - Beth Sweet [more]
Unread 07-02-2014, 10:11
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
Re: What is considered a catch
Originally Posted by JamesCH95 View Post
If you're willing to risk a non-reversible ref's call on it, go ahead.
I didn't say anything about it being worth it to risk this. There are many threads out there from the beginning of the season arguing the ambiguity of a CATCH. I'm sure there will be quite a few refs that call a launch a CATCH, and quite a few that don't. That's one of the tough things about this particular rule. If you are a high caliber team you will of course try to design a mechanism capable of performing a CATCH and actually catching the ball for control reasons.
If you are a low resource team and were only able to field a moving lunch tray there are other ways to get a CATCH. If you have a spinning paddle on top of your robot designed to hit the ball in the forward direction all you need to do is park under where the ball will land. If the ball hits your paddle and goes forward it would, according to the manual and QA, be considered a CATCH. Grandma wouldn't think so because it is not a catch, but it is still a CATCH.
2016 (mentor/drive-coach)
Quarter-Finalist-Einstein, Winner-Carson Division Champs, Winner-10K Lakes, Chairman's Award-10K Lakes, Finalists-Lake Superior,
Winner-MSHSL Robotics Competition
2015 (mentor/drive-coach)
Finalists-10K Lakes, Finalists-Lake Superior, Finalist-MSHL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2014 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior Winner-MSHSL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2013 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior, Winner-MSHSL Robotics Competition, Quarter-Finalist-Newton Division Champs
2012 (mentor/drive-coach)
Finalists-Lake Superior, Semi-Finalist-MSHSL State Championship, Semi-Finalists at 10,000 Lakes
2008-2011 (college mentor)
2007 (driver)
Quarter Finalist-Milwaukee
Unread 07-02-2014, 10:13
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I'm not disagreeing with you, I think all of your points are valid, I am just explaining why I would choose to follow the grandma rule.
Sorry if my original post did not convey that intent
Unread 07-02-2014, 10:15
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
Couldn't agree more. Both POSSESSION and CATCH are clearly defined within the rules and Q&A quoted above.
There is no reason to bring opinions on practicality and risk into the discussion as each team must weigh that on their own when designing mechanisms within the rules defined. The OP asked a specific question and the response given was correct.
Unread 07-02-2014, 10:23
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Something to keep in mind is that the same "possession" definition that applies to catching a ball coming over the truss also applies to possessing an opponents ball, which is a technical foul.
If you are prepared to argue that deflecting your own ball should count as a catch, you should also be prepared, as a matter of gracious professionalism, to argue that by deflecting your opponents ball you deserve a technical foul.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 07-02-2014, 11:57
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
I anticipate the "desired location or direction" being called very strictly with regards to catching to prevent a team from spinning a baseball bat over their robot to earn catch points. If a robot has an active mechanism directing the ball towards the next zone/far wall/friendly robot reliably I expect catch points to be awarded. I am comfortable with my interpretation of the rule but it is slightly at odds with the traditional (grandmother's) definition.
My grandmother's opinion of the rules doesn't bother me this year since an "assist" could be:
-Robot Red 1 pins ball against wall for a couple of seconds
-Every robot ignores the ball for 90 seconds
-Robot Red 2 collects it, drives it the length of the field, and scores it
-Red robot 1 recieves the ball and throws it the length of the field
-Blue robot bumps it back to the original zone ("traditionally considered incomplete or a turnover)
-Red robot 2 collects and scores
Queen's Applied Science '13, Applied Mathematics
Unread 07-02-2014, 13:12
AFron10's Avatar
AFron10 AFron10 is offline
AKA: Adrian Fronczak
FRC #3015 (Ranger Robotics)
AFron10 will become famous soon enoughAFron10 will become famous soon enough
Sorry that this may be a little off topic but when a human player catches the ball over the truss, then places the ball in a robot without the ball ever touching the ground, does that alliance receive catch points in that cycle? I apologize if this is already stated in the Q&A or the manual.
Team 3015
2015 Newton Division Finalists (195, 1756, 4522)
2014 Curie Division Quarter-Finalists (624, 987, 3476)
2 Time Regional Champions (2012 Buckeye and 2015 Finger Lakes)
3 Time Regional Finalist
3 World Championship Appearances
Career Student Record: 76-24-0
Unread 07-02-2014, 13:23
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
No, a catch by a human player is ineligible for catch points, however, when he (or she, I might add ) gives the ball to a [different] awaiting robot, assist points are received, along with the toss points.
Im not in a place to go scrounging through rules but I recall discussing this elsewhere on CD
Unread 08-02-2014, 11:34
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
I'm very interested in how this is going to be called at events this season. By the definitions and rules, this form of Trapping is Possession that would lead to an Assist. However, based on the comments of many volunteers, who are using the "grandmother rule", Trapping is not "enough" Possession to constitute an Assist. I hope that everyone is going to enforce the actual written rules, as opposed to this esoteric grandmother clause.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 08-02-2014, 12:42
It will be interesting from the standpoint of both offense - which I believe you are referring - as well as defense being played. If an opponent BLUE ball inadvertently gets trapped between the field side rail and a RED robot - even for a second, technically this is possession by the RED robot and a 50 point technical foul.
We'll see I guess.
Unread 09-02-2014, 12:34
We'll see I guess.
Very true. I think it's very interesting that the GDC used a universal definition for both offensive and defensive Possession. If I were writing the rule, I would have been inclined to use the current definition for Possession to define what you cannot do with your opponents' ball, and have a more restrictive definition on what you need to do with your own ball to constitute offensive Possesion. This would keep the same restrictions on defensive interference on the ball, but would also force teams to exhibit a more intuitive form of possession on offense. I still find the idea that a team can press/Trap a ball against the side of the field to score points, to be very counter intuitive.
