Go to Post I want to take a moment to thank every single FIRST mentor on behalf of all the FIRSTers (students) out there, for giving us the best we can get. - Arefin Bari [more]
Unread 15-02-2003, 12:24
tinsLee123 tinsLee123 is offline
AKA: Eric L
#0967 (Linn-Mar Robotics)
Team Role: Animator
tinsLee123 is an unknown quantity at this point
Send a message via AIM to tinsLee123
chains in 3ds
Hi!
I've already created a link and i want to make a chain that goes a round two gears. Is their a way to do it easily.
We already tried drawing a spline path and using deform.
Thanks for the help
Unread 15-02-2003, 12:30
MBiddy's Avatar
MBiddy MBiddy is offline
Groovy!
#0862 (Lightning)
MBiddy is an unknown quantity at this point
Send a message via AIM to MBiddy
I don't know if there's a really easy way, but the only way I know of is to create a spline path that goes around both gears and then have all the links follow each other like a train around the path.
Unread 15-02-2003, 17:42
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
Path Deform modifier is definetely the best way to do that:
1) first make an array of the links, so it looks like a straightened out chain
2) join all of the links to create a signle mesh object
3) make a spline going around the gears
4) apply path deform modifier, and change the deform axios to match the spline
5) Animate the path percent value to make the chain follow the spline
* you might have to adjust the length of your chain to make it loop perfectly
Another way to do that might be Spline IK, but path deform should work fine.
Unread 16-02-2003, 23:15
AKA: Eric L
Team Role: Animator
chain
thanks
Yeah, i tried it again, because the first time we got distortion, but now it seems to be fine.
Unread 17-02-2003, 00:14
reisser's Avatar
reisser reisser is offline
Ph.D. User
AKA: Brandon Reiss
#0103 (Cybersonics Technology Team)
Team Role: Animator
reisser is on a distinguished road
Send a message via AIM to reisser
Use a path deform as was already suggested. Then, under track view, apply a float expression modifier to the Percent Along Path attribute of the path deform. Assign a variable (call it gearrot) to the rotation of the gear on the correct axis. Make the controller equal to ((gearrot/360) * (diameter of gear * pi) * 100)/(length of path)...
What this is saying is:
Take the proportion of the angle spun to find out how far the gear has rotated (% * circumference), and then compare that to the length of the path.
Good Luck!
Doctor?
Polylines -> 3ds GavinO 3D Animation and Competition 0 06-02-2003 20:00
Another 3ds max "Key" Jack 3D Animation and Competition 7 09-05-2002 21:19
Text effects in 3DS Max... Ranma 3D Animation and Competition 6 28-02-2002 21:56
I NEED MAJOR 3DS MAX HELP!!! Ranma 3D Animation and Competition 3 28-02-2002 07:22
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
