Go to Post I keep on accidently seeing (and pronouncing) it as Chef Deli. - JJG13 [more]
Unread 07-02-2014, 14:51
SeafordVikingR SeafordVikingR is offline
FRC #4567
SeafordVikingR is an unknown quantity at this point
is 18 gage steel, used as a bracket on the chassis counted as an outward protrusion??
Unread 07-02-2014, 14:53
FRC #4567
Re: Assistance
Please Help
Unread 07-02-2014, 14:56
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Re: is 18 gage steel, used as a bracket on the chassis counted as an outward protrusi
Can you provide any more information? A picture, or drawing of what you're talking about will help.
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 07-02-2014, 15:02
FRC #4567
We are making a bracket out of sheet metal in order to mount a piston over the wheels. The bracket will go from the inner brace on the chassis to the outer brace. Are we allowed to mount the sheet metal brace on the outside of the chassis? It will be protruding from the chassis about 1/16th of an inch. Thanks in advance!
Unread 07-02-2014, 15:14
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
A picture or diagram would be helpful, but 'chassis' is not a relevant term really. FRAME PERIMETER is relevant. It sounds like the 1/16 inch protrusion would re-define your frame perimeter because it is not a fastener like a bolt head, etc (which are not considered in determining your frame perimeter.
I'm envisioning a piece that has a right angle and is fastened to your chassis on its outer face. This just becomes your frame perimeter and the chassis element will be within 1/16" and so would be allowed because it is less than 1/4" depth.
Again, the above is based on some conjecture about what you are actually trying to do, so it may not reflect reality.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 07-02-2014, 15:15
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
As long as you stay inside the max frame perimeter 112 in you will be fine.
2012-2016 Wave Robotics Team 2826
Unread 07-02-2014, 15:16
It's hard to visualize what you mean. I surmise that your steel piece would end up defining your frame perimeter, rather than being considered a "minor protrusion".
Unread 07-02-2014, 15:18
Shadowfl's Avatar
Shadowfl Shadowfl is offline
AKA: William Wrenne
FRC #2152 (S*M*A*S*H)
Shadowfl is on a distinguished road
I've found a rule pertaining to a protrusion of that diminutive size. look at 4.1 R2 and if that doesn't feel acceptable you should ask the Q&A
IF (Living) = true;
Then (Learning) ;
I have a tendency to gear my self toward puns
Unread 07-02-2014, 15:19
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
R2 is what you have to comply with. As long as a small bracket & bolt did not exceed 1/4", I would consider it a minor protrusion. At some length a bracket would cease to be minor. Inside the bumper zone it could be considered part of the frame perimeter. Legal if the rule frame perimeter rules are met. Outside the bumper zone it would have to be a minor protrusion. Q&A generally punts these kinds of questions so ultimately it will be up to your robot inspector.
Unread 07-02-2014, 15:21
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Be very careful saying that. It all depends on where the bumpers end up relative to this bracket, because if this bracket redefines the frame perimeter then it also changes their bumpers!
Unread 07-02-2014, 15:38
True, but its up to them to determine that. I was answering the question asked, and without more info or a picture I'm not going to bring in more rules to cloud the waters.
