Go to Post I won't tar and feather you, I'll disagree though. - Andrew Schreiber [more]
Unread 15-02-2003, 17:50
duckshepherd's Avatar
duckshepherd duckshepherd is offline
FIRST Veteran
AKA: Jeremy Egger
FRC #0959
duckshepherd is an unknown quantity at this point
Send a message via AIM to duckshepherd Send a message via MSN to duckshepherd Send a message via Yahoo to duckshepherd
Question CIM vs. Drill motor
I've noticed that a lot of the veteran teams are using the CIM motors. I am wondering why. I thought the drill motors were more powerful than the CIM motors. The relative mode I'm comparing is the low gear setting on the drill motor w/ clutch setup vs. the CIM motor w/o any gearing. Are the CIM prefered because they do better under autonomous contitions since they are stepper motors, or is it simply a matter of the CIM putting out more torque than the drill motors?
-Jeremy Egger
Freshman-"Could you hand me that thing that makes that clickety noise when you turn it?"
Senior-"You mean the ratchet?"
No, I refuse. Wait, what? Did you say chicken and cheese? Alright then...
Unread 15-02-2003, 18:20
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
The power/speed isn't as big of a deal for many veteran teams. Many veterans have a transmission in their gearbox to make for high torque or high speed on demand.
The biggest advantages I've seen of using the CIM as opposed to the Drill? Heat & Mounting.
The CIM's don't heat up anywhere near as quickly as the drill's do. They also have mounting points built into the motor housing making a gearbox a relitivly simple task.
With the pre-made gearboxes for teams, I expect the majority of the rookies to be using the drill's with prefab boxes and the majority of veterans having their own gearbox with CIM
Unread 15-02-2003, 18:25
jmort03's Avatar
jmort03 jmort03 is offline
jmort03 is an unknown quantity at this point
Send a message via AIM to jmort03
We are using both!!!
...OH...IO...aka Ohio State
Unread 15-02-2003, 18:36
FIRST Veteran
AKA: Jeremy Egger
FRC #0959
Our team ended up using the drill motors just because we found it easier for ourselves to mount them and also because the kit already came with couplers for the drill motors. We ended up machining those extra hex blocks that came with the kit so we could custom fit one of our shafts. You should see our drive train. We used timing chain and sprockets from a chevy 357 V8 engine. There's no way we're going to bust that
Here's a picture of last year's robot with the same drive train.
-Jeremy Egger
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
A new record for breaking a drill motor ZacharyD Technical Discussion 23 16-01-2003 16:58
External metal jacket on the Drill motor and FP motor, WHY? archiver 2001 3 24-06-2002 04:22
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
