Go to Post I knew you guys were really smokin' at Championships. I just didn't realize how much! - Mark McLeod [more]
Unread 07-02-2014, 16:02
LATech LATech is offline
FRC #4955
LATech is an unknown quantity at this point
Victors & Talons problem; motor jotering PLZ HELP!!
We are using a 4 motor configuration, we have tried both victors (4) and are currently hooked up to talons, in both cases we would try to go forward slowly and the motors would obey, as we tried to increase the speed the motors would start to "jotter"; meaning go forward then quickly go back then forward again. At first we thought it was the victors, which we replaced with talons (which we calibrated) and got the same result. We also switched out the PWM cables with no success, so we don't think it is faulty cables. Please help us as we cannot diagnose the problem.
One possibility is that we accidentally sparked a PWM cable (connected to the digital sidecar) onto the aluminium chassis with everything in it. The battery was connected but switched off (yet there was still a spark. We assume residual power was present and that a negative was touching the chasis).....We don't believe any damage was done to the C-RIO because it still works but we are not sure if the digital sidecar took any damage. If the digital sidecar is damaged then would it be causing this jotter of our motors?
Unread 07-02-2014, 16:07
steinra's Avatar
steinra steinra is offline
(KG7KEO)
AKA: Randy Steiner
FRC #5461 (V.E.R.N.)
steinra is on a distinguished road
Re: Victors & Talons problem; motor jotering PLZ HELP!!
First check your digital side car and make sure all 3 power lights are on. Unplug from the cRio to make sure.
If they are not, your spark could have caused an issue on the digital side car.
If those are on the next item to look at would be the PWM routing. Do they come anywhere near the power wires going to the motor? If so try moving them far away. We had an issue last year where the power wires for the motor were right next to a servo line. The induces voltage from the variable speed on the motor lines cause jitter in the servo. When separated that problem went away.
Randy
Randy Steiner
2014-2015 FIRST Team 5461 - Coach
2011-2014 FIRST Team 4106 - Head Mentor
2007-2011 FIRST Team 1891 - Mentor
