Go to Post 2010 game piece--- participation medals - johnr [more]
Unread 07-02-2014, 15:33
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Arm Position Control
If there were a stationary attachment point located vertically above the pivot, and of sufficient height, one could secure the tubing to that point and to the arm. That would provide minimum torque at noon and maximum torque (of opposite signs) at 3 and 9 o'clock.
Barring such an arrangement, what other options do you have in mind?
Instead of 1 right above it 2 on either side level with the rotation point. It wouldn't be as optimal as a point right above it but it would help a bit. As you move those points higher they help more and more.
Unread 07-02-2014, 15:36
I think we can assume a suitable attachment point vertically below the pivot. A short extension on the opposite side from the arm would provide a way to use a downward force to counterbalance it.
A sprocket-and-chain scheme can put a "virtual pivot point" anywhere convenient.
Unread 07-02-2014, 15:39
If they are level with the rotation point (by this I assume you mean the arm pivot), they provide zero torque at the extremes (where it is most needed).
Unread 07-02-2014, 15:43
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
-In the context of an arm, velocity PID is useless. It would not provide the desired response at all.[/quote]
Maybe i read his question wrong but if you are wanting to move the arms from 0 deg to 180 deg and have your controller take into account the increased torque a velocity PID controller would be perfect for this.
This would allow the arms to move at a constant angular rate regardless of the torque needed.
However this would not allow the arm to stop right at 0 and 180 deg. To do this you would need to transition from the velocity control to a position control when you got close to your desired position.
Unread 07-02-2014, 15:44
Flywheel Police
Correct, it would be more optimal between the 45's but past that it would not help as much.
Unread 07-02-2014, 15:49
Flywheel Police
Or even extend the arm through the pivot point and attach the bungee to that point and directly below the pivot point.
Unread 07-02-2014, 15:51
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Or you could rely on the derivative control to slow it down properly.
Stacking and switching PID controls is usually a lot more work than it's worth.
I agree Joe, the need for any gain scheduling or other controls is dependent on the arm. Some arms need adjustment, some do not. I have worked with both.
Kettering Motorsports
Unread 07-02-2014, 16:01
Yes, of course; that's a mirror image of the on-top approach... except with much higher forces (due to smaller distances).
Unread 07-02-2014, 16:06
Flywheel Police
Exactly.
Unread 07-02-2014, 16:11
Flywheel Police
You could also use a gas spring to limit the speed that the arm could move. Set up the same as my last suggestion. It would give you hard stops on both ends, it wouldn't help with the torque but it would help with the reaction time of the pid being different in different locations.
Unread 07-02-2014, 16:13
Bpk9p4's Avatar
FRC #1756
[quote=apalrd;1339275]Or you could rely on the derivative control to slow it down properly.
The D term just slows down the response of the system not the overall speed of the system at Steady State.
You are correct though that switching between two controllers needs to be done carefully.
Unread 07-02-2014, 16:17
That depends on how the "D" in your PID is implemented.
Unread 07-02-2014, 17:25
apalrd's Avatar
More Torque!
VRC #3333
In PID:
-P is the error of the position
-I is the accumulated error of position (steady state error)
-D is the velocity and often opposes the other two terms
A proper D gain will compensate for the velocity. With all of the gains set correctly, there will be a point where the error is so great that the sum of P, I, and D is larger than the motor's max output, so the negative D term will have no effect. As the arm slows down, the D term will compensate for the velocity (inertia) as the arm approaches the target.
When I calibrate PID loops by hand, I usually only end up with a PI controller. I have tried to add D manually with little success. When I calibrated automatically (using the ultimate stability method), I found that the D gains were many times what I was getting by hand, but the system worked beautifully.
On a side note, I autotuned a full PID loop on two VRC robots (relatively high intertia, fast gear ratio, more counterforce than gravity long arms) and found that a single PID gain set was adequate. On a cam driven linkage on our 2012 FRC robot, I needed to schedule the gains because the motion ratios changed significantly over the stroke.
Unread 07-02-2014, 17:48
Jared's Avatar
Jared Jared is offline
In PID:
It's really tough to get a D term to compensate for the inertia of an arm. In order for the D to really affect the system the way you want it to kD must be fairly large, which requires that kP and kI be pretty much perfect.
You could also adjust your gains based on where the arm is.
The way to tune this is to set up three or four different PID loops, each of which are tuned to make the arm respond nicely when going to a specific place. Then, you can take your kP/kI values that work for each of the locations and find a nice curve that fits them and use that curve to modify the gains based on where your arm is.
As for preventing integral wind-up, I just turn off the I term until we are withing 10 percent of the target.
Unread 07-02-2014, 17:57
apalrd posted the same idea earlier in the thread.
-Gain Scheduling. You would have a no-gravity and peak-gravity gainset (kP,kI,kD) and blend them with the angle.
