Go to Post Well, the cake could either be a simple cake Or It is blue, so that obviously means that we are having a water game this year. - big1boom [more]
Unread 07-02-2014, 16:07
steinra's Avatar
steinra steinra is offline
(KG7KEO)
AKA: Randy Steiner
FRC #5461 (V.E.R.N.)
steinra is on a distinguished road
Re: Victors & Talons problem; motor jotering PLZ HELP!!
First check your digital side car and make sure all 3 power lights are on. Unplug from the cRio to make sure.
If they are not, your spark could have caused an issue on the digital side car.
If those are on the next item to look at would be the PWM routing. Do they come anywhere near the power wires going to the motor? If so try moving them far away. We had an issue last year where the power wires for the motor were right next to a servo line. The induces voltage from the variable speed on the motor lines cause jitter in the servo. When separated that problem went away.
Randy
Randy Steiner
2014-2015 FIRST Team 5461 - Coach
2011-2014 FIRST Team 4106 - Head Mentor
2007-2011 FIRST Team 1891 - Mentor
