Go to Post FIRST is an opportunity for me to tackle problems that have long been solved. - Madison [more]
Unread 15-02-2003, 18:37
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Questions regarding textures in 3D Studio Max
Hi everyone. I've been having a few problems with texture lately, so hopefully you can help.
In one of our scenes in the animation, we've filled all of our texture boxes up (and it's at its smallest size meaning the spheres are all small)... is there any way I can get more texture boxes in the material editor?
Also, how would I go about doing a double-sided texture, like one texture on one side of a sign... and another texture on another sign.
Oh yeah! One more thing this has nothing to do w/ textures. How does one make an Omni light not so bright? they're waayyyy too bright when I add them into scenes. Thanks!
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 15-02-2003, 19:21
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
Okay...answer time:
Part A: There is a button that puts the currently selected material sphere to libarary (called put to library). That will put them into the library. Then, go into the library and SAVE it. Once you've done that, you can go back to the material editor and juss erase those spheres. The object will retain the texture (as long as you make a new texture entirly) and you cna then use that sphere for anotehr texture. Then, to reimport a texture, either open it from teh library or do a "From scene..." for the texture selection.
Double-sided texture: Okay, I'd recommand you convert the object to an editiable mesh, and assign each part of the mesh a SelectionID (at the bottom of the modify panel). Then make a Multi/Sub-object texture. Texture number one will correspond to Selection ID one, Texture number two on the mutlti-subobject will correspond to Selection ID two. That should get ya going there...worst comes to worst, make a plane and use a double sided texture as far as signs go.
OmniLighting: There is an intensity setting on the omni lights. In the lights and cameras tab, there is a lgiht lister. THat lets you set the settings for all your lights. it is your friend, use it. lol
and remember...targa! targa! tooga, er, i mean..targa! targa!
Remember, IM me if you need help, thats why my s/n's in my sig.
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 15-02-2003, 23:03
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
There is a much easier way to do that - use a 2-sided material
1) open material editor
2) select a material slot and click on the material type button at the top (usually says Standard, Raytrace, etc)
3) Select Two-Sided from the list
4) assign the materials to each side
hope this helps
Unread 16-02-2003, 01:07
AKA: Jim Martz
hope this helps
BUT the problem with that lies on that all it does is on the opposite side of the FACE (thus the INSIDE of a box) would have the other texture. The object your applying the texture to must be 2d to get it to work right :-\ i thoguht about that for a few minutes and suddenly realize waht was worng... sorry..
Unread 16-02-2003, 09:06
Lev's Avatar
Lev Lev is offline
I guess, i misunderstood the question... I thought that by the double-sided texture AnimeRaul234 wanted exactly the different textures on different sides of mesh FACES.
I would think that a sign is most likely just a flat 2d object. But, if the sign is a non-flat object, the Top-Bottom material will be your friend. The direction are similar to the Double-Sided Material.
Unread 16-02-2003, 10:32
AKA: Jim Martz
Yeah, i thoguht about that too for a sec. BUt then I thoguht, if your doing a dobule sided sign, your proboly going to be rotating around it at some point, and if thats the case, having a 2d object would look really weird at the point where the camera is staring straight down the side. It would appear that the sign dissapears for a moment. so it would have to be a reallllyyyy thin box, thus making the double sided no worky... again, im not trying to like prove ya wrong, i juss dont want him to sit there going "why wont the double sided work on my box..."
Unread 16-02-2003, 14:26
cooldude841 cooldude841 is offline
cooldude841 is an unknown quantity at this point
If you have textures that you arent animating, and youve already assigned them to objects and have no need to change any parameters, do this.
Click on the texture in texture editor and click delete. A box will come up asking you if u want to just effect the editor slot or affect both object in scene and editor slot. Click only affect editor slot and it will give you a new, empty box for more texturing fun and it wont change the objects that have the earlier assigned texture.
How do you create your own textures in max? Hailfire 3D Animation and Competition 9 04-01-2003 21:19
3d studio max, how do you guys do it. archiver 2001 3 24-06-2002 03:51
3-d studio max archiver 2001 21 23-06-2002 23:28
Question about 3D Studio Max ee_capp 3D Animation and Competition 0 01-02-2002 15:49
3D Studio Max AJ Howard 3D Animation and Competition 1 18-01-2002 17:58
