Go to Post Mentors: Don't give up folks, your efforts are not in vain. The kids get something out of it whether we get acknowledgment or not. - Swampdude [more]
Unread 07-02-2014, 17:02
Doris Arias Doris Arias is offline
FRC #0564
Doris Arias is an unknown quantity at this point
Battery voltage on dashboard.
We are having problems getting our dashboard to display the voltage of the battery, we think we have the code right but the value isn't being printed, any suggestions? we think it might be a wiring issue.
Unread 07-02-2014, 17:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Battery voltage on dashboard.
Did you connect an anlog input to the power distribution board, so it has something to measure?
Unread 07-02-2014, 17:13
What wiring do you think you need in order to read the battery voltage? What programming are you doing in order to send it to the dashboard, and what are you doing in order to display the value that is sent?
But most importantly, why do you want to show the battery voltage on the dashboard? It's already prominently displayed on the Driver Station.
Unread 07-02-2014, 19:56
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The 2014 version of the analog breakout board does not have a jumper. And no place to put one.
Unread 07-02-2014, 21:24
Good to know. Thanks Frank.
Unread 07-02-2014, 23:07
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Ditto - thanks for the heads up Frank!
Unread 07-02-2014, 23:12
Doris,
The number one problem here is the failure to wire a 12 volt output of the PD to the analog module. Following that, on pre-2014 analog modules, is the insertion of the jumper on the left edge of the module.
