Go to Post Now, I either need to convince Mike Martus to start the webhug early (or move it back 1 hour), skip the webhug, miss the first part of the presentation, or just clone myself. - Andy Baker [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 07-02-2014, 16:59
Vkamra20 Vkamra20 is offline
FRC #5094
Vkamra20 is an unknown quantity at this point
Victor Speed Controllers
We just finished out Robot, but now our Victor Speed Controllers are neutral and won't work. Any help would be appreciated.
Thanks
Unread 07-02-2014, 17:05
Re: Victor Speed Controllers
Originally Posted by Vkamra20 View Post
...but now our Victor Speed Controllers are neutral and won't work
You seem to be implying that your Victors were working fine at some earlier time (this season), but now are not working. Was that your intended meaning?
Unread 07-02-2014, 17:06
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
When you enable your robot, do the orange lights on the speed controllers turn solid, or do they continue to blink?
Likely, you don't have a good connection between your victor and your digital sidecar. Victors are extremely finicky to plug in.
Unread 07-02-2014, 17:10
FRC #5094
Yeah, the victors were working earlier.
Unread 07-02-2014, 17:13
FRC #5094
We have four Victors, three are blinking and one is solid orange.
Unread 07-02-2014, 17:17
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Check here for what the status codes on control system components mean:
http://wpilib.screenstepslive.com/s/...s#!prettyPhoto
Victor:
  • Green - full forward
  • Orange - neutral / brake
  • Red - full reverse
  • Flashing orange - no PWM signal
  • Flashing red/green - calibration mode
  • Flashing green - successful calibration
  • Flashing red - unsuccessful calibration
http://team2168.org
Unread 07-02-2014, 17:24
Are the blinking ones blinking orange?
Blinking orange means they are not getting a valid PWM signal.
Look carefully at how the PWM connector is installed into each of the 3 Vics that are blinking, and compare them to the one on the Vic which is solid orange.
