Go to Post Swerve Drive (n.) - a set of mechanisms to ensure the robot will sit dead on the field for half of that robot's first event - Kevin Leonard [more]
Unread 07-02-2014, 17:40
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Re: How to Use a Manifold
What is the model of the manifold you are using?
Unread 07-02-2014, 17:50
ybansal17's Avatar
ybansal17 ybansal17 is offline
FRC #1967 (Janksters)
ybansal17 is an unknown quantity at this point
VABM-L1-105-G18-4
Mat. -Nr.: 566560
Serie: D902
it holds solenoid VUVG-L10-B52-T-M7-1P3
i don't know if it matters...but on the three tube connecters for the manifold to connect to the pneumatic tubing...it's number 1 in the middle and then 3 and 5 on the sides
Unread 07-02-2014, 20:13
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
The center port supplies air and the ports on either side of it are the venting holes for the valves that are mounted. I think the holes are repeated on each side of the manifold. If so, plug the center one on the far side unless you are supplying air to another solenoid or mounting pad from it.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 07-02-2014, 21:36
ybansal17's Avatar
ok...thank you
