Go to Post "Greatness isn't achieved by doing the uncommon things but instead by doing the common things uncommonly well." - Wayne C. [more]
Unread 08-02-2014, 09:44
mechanical_robot's Avatar
mechanical_robot mechanical_robot is offline
Team Role: Driver
mechanical_robot will become famous soon enough
Smartdashboard in Java
Alright so my team is using C++ for the actual code running the robot. My question is is there anyway at all to use Java for the smart dashboard? If so please tell me. I just prefer the code for the smart dashboard be in Java. Though if there is no way could you point me to some good tutorials for using smart dashboard with C++.
Unread 08-02-2014, 11:37
Re: Smartdashboard in Java
I'm not sure what you're asking. SmartDashboard is a Java program, designed to communicate with either a Java or C++ robot. For most use cases, it is not necessary to modify SmartDashboard, because it dynamically adapts to the data your robot is sending.
I'd recommend reading http://wpilib.screenstepslive.com/s/3120/m/7932. While the robot examples are generally in java, the same methods exist in the C++ SmartDashboard class.
